Did I just do this for nothing (almost)?
Another aspect of 996 paranoia got to me. The temp gauge touched the zero, so what do I do? Take off the whole gosh darned front end of the car, of course. This is what I found. Oh well, at least I have piece of mind and can detail parts of the car nobody will ever see...
What was the ambient temperature...over 100f? Are you sure your fans low and high speeds are working on both sides? How old is your water pump. How old is your coolant. How old and what number is on your radiator storage tank cap?
Those don't look that dirty...
How's your paranoia level now?
Would be surprised to learn that this temp is actually 206F on my car according to the computer (DME from ODBII, verified also with Durametric)? And all these folks that complain that the low speed and high speed fans don’t come on at the right temps are all basing their temps on this gauge, which is off by as much as 10-12C. You are not even getting anywhere near the boiling point of water.
My water pump is 18 years old. Be ready for fire, brimstone, and eternal damnation- the coolants probably 18 years old as well. Yes, both are in the agenda to be changed soon.
FWIW, cleaning even the little bit of visible debris DID make a difference. Here are my very scientific observations; in slow extended drives in “subdivision speeds”, I.e. stop sign to stop sign or almost city type driving, my car has always sat at the left side of the zero in 180. Even if I turn on the AC to get the fans going, it mattered very little. Yesterday, I took a 10 mile drive in such conditions with nearly identical temps/conditions to today and the temp gauge covered the left side of the zero in 180. Today I drove the same route and the needle never left the right side of the 8 in 180. So, I guess it does make a difference in the efficiency of the radiators. Lastly, when warm, the oil pressure would be just below 2, today it sat just above 2.
I’m just surprised how big of a difference the little bit of debris made. I’m pretty sure I drove long enough to get it hot as it was all through subdivisions. Even though I only went ten miles it was a good half hour. I normally don’t drive through subdivisions, but I did so yesterday knowing I was going to clean the radiators today, that and I know that’s when it runs the warmest.
