1997 Viper GTS
1997 Viper GTS
Year: 1997
Make: Dodge
Model: Viper
Mileage (numbers only please): 29800
Options (Please check ALL which apply): Airbags, Air Conditioning, Foglamps, Intermittent Wipers, Power Brakes, Power Door Locks, Power Steering, Power Windows
Color: Red
VIN: 1B3ER69E1VV300350
Price (no $ sign please): $38000
Location (Region): NorthEast
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Heavily modified the RIGHT way 1997 Viper GTS. Fully documented with every receipt, notebooks, tuner etc. One of the highest HP naturally aspirated Gen2 Vipers on the road! 650+ HP, over 700+ TQ on a SAFE, rich tune! ONLY selling as want a back seat, even if a small one
Modifications as follows:
Jeff Morey Stage 3 Heads and Cam
10.5:1 Compression
APR Head Studs
Bellanger Headers and exhaust, just passed CT State Emissions on 11/3/16
Accufab Throttle Bodies
Ported Intakes
Stage 8 locking header bolts
T&D Rockers
Trick Flow chrome molly push rods
50 lb injectors, balanced by Tony Armour
Gen3 fuel pump
Ignition cut-off switch
2000 model year 10 qt oil pan with windage scraper and hinged trap door
Pre-oiler. Car NEVER starts dry!
ACR Oil filter adapter
Custom cold air box
Red silicone radiator hoses with bleeder
Catch can
ROE valve cover breather
Underdrive pulley
Burping T at heater box
Upgraded spark plug wires (high heat) and custom looms
John Dinoto built transmission
SVS billet shifter
Billet cross member
SPEC Petal style clutch (will include a spare SPEC clutch pressure plate)
Roe clutch pedal travel reducer
Driveshaft safety loop
Aluminum belly pan
Archer anti-toe brackets
Half shaft loops
SCT Pro Racer X2 Tuner
Innovate A/Fgauge and logger (DL32)
Voltage and fuel pressure on A pillar
Raptor shift light (never used, turned off)
Race alignment
19" CCW wheels with NEW Nitto tires (under 200 miles)
BTR Roll bar, powder coated red
Woodhouse adjustable sway bar
Engine bay fire suppression system
Tow eyes front and rear
Power steering captive cover and breather
Tom's upgraded rear brake kit with proportioning valves, ungraded Stoptech drilled /slotted rotors. Brakes are 1 year old
Brand new Master Cylinder
Custom rear brake caliper covers
Differential pinion arms with poly bushings
Professionally installed 3.55 gears from PartsRack
Carbon fiber center console
Carbon fiber radio surround
BOSS Audio flip out 7" DVD, bluetooth, phone connect GPS. (the GPS seems to be not working lately. Wire disconnected)
Fully sanded and professionally painted dash, satin black
Chrome gauge surrounds
Loyds Sneaky Pete logo floor mats
Gen3 seats, recovered by Venzano in fabric with Gen3 Viper logo
5 point harnesses, driver and passenger
Redline shifter boot
Air Flight aluminum pedals and door sills
Painted Viper logo hood pad
MGM short shifter
MGM Radio/AC *****
MGM console compartment with cup holder
MGM lighter, ash tray gas cap and door
Custom ACR style wrap by ACI Wraps in CT.
Extremely well sorted car. I may be new here, but very well known in VOA and local Viper Club. Car is well documented on VOA forums and on social media.
What needs to be done to car?
The AC works but won't hold a charge. Is a very common issue on these cars for the O rings to dry out. I have never bothered to replace them as even with the AC on full blast, you need the windows open. The motor, transmission etc just make too much heat. Car NEVER runs hot btw.
There is a small oil drip from somewhere from the pre-oiler. I have not spent long chasing it as it doesn't effect oil level or pressure. It will at times leave a drip or two on your garage floor. Is better to have a could drip IMO and have the car pre-pressurize with 25lbs oil on start then to worry about a drip.
All the other "Viper quirks" have been sorted and fixed! Turn the key, wake up the neighborhood and hold on!
hard to believe this beast is ~20 years old!
have you had any paint work done, or any issues?
