NEW 1973 911S TARGA
NEW 1973 911S TARGA
Year: 1973
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 750
Color: SILVER
VIN: 9113310083
Price (no $ sign please): $225000
Location (Region): Midwestern
Body Style: Targa
Engine Type: Fuel Injection
Stereo System: None
The exterior was completely stripped to metal and repainted in its original color of metallic silver. Every bit of rust was removed and replaced with Porsche steel and assembled by a true craftsman. The wheel wells and underside were completely restriped to rule out any possible corrosion and recoated with Werth undercoating. The interior floor pan was stripped down and recoated as well. There is not one bit of rust or bondo on this car. The Targa top was reupholstered using the correct vinyl by Dave Brown of Boulder Co. All seals, rubber and hoses are new. All trim was either replaced w/ OEM trim or restored by Kings of Trim. The restoration of the original lettering and engine deck lid grill by Kings of Trim is amazing. The old windshield was replaced with a brand new OEM correct windshield.
The original engine block was lost to history and replaced by a 7R block as opposed to the original 5R used in the early 73 production cars. The remainder of the engine is original. It was completely rebuilt by Tim Owen of Topeka Kansas. The case, heads and crank were sent out to Ollie’s for reconditioning and preparation to be converted to a fire breathing 2.7L RS engine. All new 2.7L cylinders, S pistons, bearings and seals were installed along with Carrera chain tensioners. An original, date correct, S MFI pump was rebuilt and installed along with completely restored stacks, injector lines and throttle bodies by Eurometrix. All new injectors are installed. The oil cooler and oil tank have been restored by Pacific Oil Cooler. Although not originally equipped with, an all-new ’73 correct trombone fender oil cooler and plumbing was installed to keep the bigger engine cool. A new red heat shroud is used and all tin has been powder coated black. The transmission was completely rebuilt. A new Sachs clutch kit was installed, the flywheel was turned and balanced and all shifter bushings were replaced. The starter and alternator are brand new. The fan and housing were restored by Mark Motshagen. The distributor was rebuilt by Burnham performance.
All wiring harnesses are new from Kroon. The electrical panel from the engine bay was completely restored and the CDI was rebuilt by Bob Ashlock.
Its original Fuchs have been restored by Harvey Weidman and new tires installed, including the spare. The ride height has been set to Euro specs. The brake system was completely rebuilt including all calipers by PMB, brand new pads, discs, master cylinder, soft lines and replated hard lines.
The interior had the front seats rebuilt with top grain soft leather and the door tops and dash pads were reconditioned by Tony Garcia of Autobahn Interiors who also provided the new, correct carpet. The remainder of the interior has been completely redone and restored to original to include new (correct date stamped) front seat belts and reels. A brand new dash from Lakewell was installed as well as a new speaker. The original gauges, including a 180mph speedometer were reconditioned and updated by North Hollywood Speedometer and work like new. The car was originally radio delete and remains so today. Every piece of plastic and rubber in the cabin has been replaced with new pieces.
All of the suspension has been completely rebuild with all new bushings, bearings and new Koni shocks. All parts have been either repainted or powder coated black. The steering rack was completely rebuilt and a new Turbo tie rod kit has been installed.
The car comes with the original owner’s manual, jack; most of the tools and case, Porsche COA and paperwork dating back to the 1970’s which includes records for the recent restoration. The sale will also include a flash drive with pictures detailing the restoration. The car runs and drives just like you would expect a ’73 911S to run, only faster.
Links to photos:
Finished Photos
https://www.dropbox.com/sh/0yknedes3...TBDKaWR5a?dl=0
Targa Story Photos
https://www.dropbox.com/sh/6sujqm9it...Q5_AHJG6a?dl=0
ESR Story
http://www.early911sregistry.org/for...ght=1973+Targa
Gorgeous early 911! I have a '70 in same color combo that is a 3 year restoration. Best of luck with sale!
