1988 911 Commemorative Edition Coupe
1988 911 3.4 Commemorative Edition Coupe SOLD!
Year: 1988
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 105000
Options (Please check ALL which apply): Air Conditioning, Foglamps, Intermittent Wipers, Leather Seats, Power Door Locks, Power Windows, Sunroof
Color: Diamond Blue Metallic
VIN: WP0AB0917JS120491
Price (no $ sign please): $0
Location (Region): NorthEast
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Located in MA, over 120 pics here:
http://www.flickr.com/photos/6834381...57701081109464
General:
Third owner (PCA member) owned since 2006. Limited Commemorative Edition, only 1 of 187 coupes of the 300 total cars imported to the US in 1988. Diamond Blue Metallic paint, matching Fuchs, badge delete and Ferry Porsche Signature seats.
Records since 1990.
Looks, starts, runs, drives and sounds excellent.
Option Codes:
CO2- 48 state catalytic converter
158 - Reno Radio
243- Short shifter
498 - Badge delete
650 – sunroof
980 -Supple leather
Engine:-Less than 1k miles on major engine work:
Original 3.2 engine case, head and cylinders (bored/honed) with 3.4 JE pistons running 9:8 to 1 compression. Dynoed at 217.68 hp and 208.24 lb.ft
- Complete cylinder head job with new valves, guides, springs, exhaust studs
-964 Cam profile by Dougherty Racing Cams
-Reconditioned connecting rods with new bushings, bearings and ARP rod bolts
-New OEM chains, sprockets, rocker arm shafts, reconditioned rocker arms (Dougherty)
-ARP Head studs
-Custom Steve Wong Chip: Dynoed at 217.68 hp and 208.24 lb.ft
-New plugs, cap rotor
-All new engine bay, main engine fuel lines
-Rennline Semi Solid engine mounts
-Fabspeed cat by pass with O2 Sensor (original cat included with sale)
-Danske Sport muffler
-All engine tin stripped and powder coated
-All fuel injectors bench tested, flow cleaned by WitchHunter Performance
-New cylinder temperature sensor
-New RMS
-Engine work done by Conway Autowerks in Hanover, MA. (781) 924-5174
-Transmission
- G50 with factory short shifter
-Clutch fork update and new input shaft seal
-Cleaned bellhousing
-Less than 10k on clutch
Suspension:
Complete refurbishment with all parts removed installed new and or powder coated
-Re- Indexed and set at Euro height
-Bilstein HD front inserts, Sport rear shocks
-New OEM Turbo tie rods
-Bumpstear kit
-New Lemforder ball joints
-Steering rack removed, cleaned, lubricated
-Elephant Racing A-Arm and camber plate bushings
-All 4 CV joints refurbed: disassembled, cleaned repacked with new gaskets
-New front/ rear sway bar bushings
-New trailing arm bushings with new drop links installed
-New Spring Plate covers
-Professional string alignment by Conway Autowerks
-Brakes
-New pads, front rotors, rear lines, front main lines
-Reconditioned calipers, pistons, with new gaskets
-Reconditioned front hubs with new races and bearings installed
-Rear wheel bearings have less than 10k miles
Other:
-Engine bay heat back date with Reed switch modification so footwell blowers still work. Original blower fan assembly and original Reed switch included with sale.
-J.West headlight relay kit installed
-New DME relay installed in ‘06
-Front condenser blower fuse installed
-R134 conversion with new receiver / drier
-Vintage 80’s Alpine stereo with 4 new speakers
-New window switches
-New door seal gaskets
-Momo MOD .07 Black suede steering wheel, (original included with sale)
-New battery installed 2017
-New oil tank sending unit, fuel pressure regulator
- Rebuilt Alternator (Valeo)
-All underbody AC hardware removed cleaned and plated.
-All electrics, work, windshield washer and clock included
-Original wheel locks and key included
-Excellent dash, door panels and headliner, wear on drivers seat bolster, carpets
Exterior/Paint
All panels straight, no accidents. Looks like rear qtr and front hood were painted at some point. Doors and front wings look original.
A few small scratches/dings but no major flaws. Rear window trim has marks on it. Tires are Pirelli P6000
dch.911@gmail.com
Thanks Chris, its a great street car that can be easily run AX or DE's with the correct tires.
I've been registered on Rennlist since 2001 but have not been active on the boards for a few years. Most all of the mods and upgrades are from input from here and Pelican from over the years.
I'd be happy to answer any questions and put any interested buyer in contact with the shop who recently did the engine work.
Dave H.
Dave H.
1988 Porsche 911 Carrera for Sale, 105k miles Price: $65,000
General:
Records since 1990.
Option Codes:
158 - Reno Radio
243- Short shifter
498 - Badge delete
650 – sunroof
980 -Supple leather
-ARP Head studs
-New RMS
-Transmission
Suspension:
-Bumpstear kit
-Brakes
Other:
Exterior/Paint
dch.911@gmail.com
General:
Records since 1990.
Option Codes:
158 - Reno Radio
243- Short shifter
498 - Badge delete
650 – sunroof
980 -Supple leather
-ARP Head studs
-New RMS
-Transmission
Suspension:
-Bumpstear kit
-Brakes
Other:
Exterior/Paint
dch.911@gmail.com
