Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
930 For Sale
Old 05-15-2018, 11:27 PM
Chris Rizzo
4th Gear
Chris Rizzo's Avatar
Talking 930 For Sale
Year: 1983
Make: Porsche
Model: 911
Mileage (numbers only please): 89700
Options (Please check ALL which apply): Power Windows, Sunroof
Color: Burgandy
Price (no $ sign please): $82000
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Superb European 1983 Porsche 930 Turbo molested in all the right ways
Call Chris, mobile (281)-984-8034
Asking $82,500 OBO.
Mileage: 89,700
Vin no: WP0ZZZ93ZDS000628
All documents, over $50k in receipts
Motor (matching numbers)
Complete split case rebuild by Poudre Sports Car
New jugs, C2 Mahle fully finned, thermal coated
New Mahle pistons, tops ceramic coated, dry lube skirts
7:1 compression
Rod bolts, Raceware Hardware
Head Studs, Raceware Hardware
New exhaust valves
SC Cams
new rocker armsNew timing chain and latest chain tensioner upgrade to 84' design Billet Sump plate w new drain plug
Smart Racing motor mounts
Fuel System
Fuel Injectors balanced by C&C Fuel Injection
Modified Euro fuel head to flow 17% more fuel
Both fuel pumps replacedWUR modified with use of MSD rpm activated switch for on boost fuel enrichment (w rpm modules) Surge filter for fuel cuttoff
Ignition
MSD rpm activated fuel enrichment system
Recurved distributer by Jerry Woods
Beru spark plug wires
Air Intake/Turbocharger
Kokeln intercooler w billet CBV
Power flow intake
Ram/Cold air intake to turbo done by Redline Motorsports
Throttle Body knife edged
Manifold extrude honed for even air flow runner to runner
Injector blocks tapered to match manifold portsModified Kokeln turbo (550hp), 60-1 compressor wheel w a .71 A/R, 360* thrust washer and Stage V turbine Tial 46mm wastegate with .6 bar spring
Water mist system for intercooler and oil cooler
Modified AAR for better idle when cold
ExhaustGHL headers with heat and after market sump (more power and quicker spool) Cat deletedDual look Fabspeed muffler with wastegate pipe and 4.5" dual polished tips The combination of all sounds like nothing else.....
Oil Cooling
Aftermarket oil cooler between oil tank and engine cooler
Elephant racing finned supply line to front mounted oil cooler
Kokeln Racing oil cooler with fan
Fog lights removed for ducting
Transmission(matching numbers)
Trans rebuild by Carquip8:39 Ring and Pinion done by Carquip, speed tested to 188mph w stock R&P 40% LSD with Swepco 201 trans fluid
WEVO shifter w race ****
Smart Shifter Coupler and Bushings
Hi Torque StarterKEP Stage II pressure plate (11 lbs lighter and rated for 600 ft/lbs torque) w new throw out bearing993 disc and new stock flywheel (better inertia w stock compression) New clutch cable
Rebuilt drive axles
Suspension
Kokeln Racing front strut brace
Front and Rear Sander Eng. Torsion bars 22/31 mm
Rear Sport Shocks
86-89 front and rear sway bars w/ new bushings
Tarrett Eng. Rear drop linksSuspension aligned and corner balanced with load checker, front 38% rear 62%
Brakes
2nd Gen w Pagid pads (blue)
Stainless Stl brake lines
OG Racing front cool brake kit
Wheels and Tires
18" RH 3.6 knockoffs with Al Porsche crest center caps
Goodyear Eagle Front - 245 55 18 Rear - 285 40 18
Interior
Recaro Speed line seats
AJ USA sport steering wheel and hub w manual rack and pinion
Porsche Al door handles
WEVO shifter and boot
Greddy Profec B boost control (vary by 60 RWHP)
Westach vac/boost guage
UEGO 1000 A/F wide band
Crest on Glove box
Turbo door sillsOdessey PC 680 battery (only weighs 15 lbs, these are nuts, u will never go back) Upgraded Headlight bulbs to 80/100 watts
Moonroof
AC deleted
Dyno tested 450 RWHP at 1bar, now dialed back a little.
The Bads
repaired paint spot at top of driver door jamb
Glove box light does not work
dashboard starting to warpIgnition sometimes does not catch when turning key. I have lived w this for 10 years and it has never let me down. No spare
No cat (removed and sold)
Small chip in windshield
Original fully complete tool kit, air pump, and jack(damaged)
Don't be fooled by the odometer. Important items relating to mileage have been expertly maintained or replaced. This car is extremely fresh at the moment. The chassis is in exceptional condition. It has never seen a winter and rarely rain
Chris Rizzo is offline
Old 06-03-2018, 12:43 AM
Chris Rizzo
4th Gear
Price reduction, 80K. Motivated to sell.
Old 06-20-2018, 11:35 PM
Chris Rizzo
4th Gear
Bump to top
Quick Reply: 930 For Sale
