Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
1978 Porsche 928 (#338)
Old 11-18-2018, 08:19 AM
TJsBeer
TJsBeer's Avatar
Default 1978 Porsche 928 (#338)
Year: 1978
Make: Porsche
Model: 0
Cont. Porsche Models: 928 (all)
Mileage (numbers only please): 64700
Options (Please check ALL which apply): Air Conditioning, Foglamps, Intermittent Wipers, Power Steering, Power Windows
Color: Silbermetallic
Price (no $ sign please): $30000
Location (Region): NorthEast
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM Radio
Early 1978 Porsche 928 5-Speed (#338)
Vin# 9288200338
64xxx miles
  • Purchased from Jim Doerr of 928 Classics in March 2018.
  • Refinished Phone Dial Wheels with new center caps
  • No Sunroof - No Rub Strips
  • Porsche Certificate of Authenticity
  • Working A/C
  • Fully functioning electrics.
  • Interior completely refurbished by Robert Budd of Classic9.
  • Mechanics and electrics fully sorted by Jim Doerr of 928 Classics and Stan Kolen (MrMerlin)
  • Original spare tire, Webster spare tire compressor, jack with bag, tool kit with yellow screwdriver, OSRAM spare bulb kit, spare belt with tag, two spare spark plugs, tire changing gloves, spare tire cover, first aid kit.
  • Several ‘78 only features: stainless steel gas cap, battery box cover, small louver center vents, chrome door lock surrounds.
  • Matching ignition, door and hatch locks. (One key fits all)
  • Very good quality glass-out respray in its original Silbermetallic.
  • Includes complete nine-volume Porsche 928 Workshop Manuals.
    This early production 1978 Porsche 928 is #338. Finished in Silbermetallic over a Black & White Pasha interior with refinished 15” refinished Phone Dial wheels, new center caps, no sunroof, no rub strips and a Borla cat-back exhaust system. Power is provided by a 4.5-liter SOHC V8 paired with a rear-mounted 5-speed manual transaxle.
I purchased #338 from Jim Doerr of 928 Classics in March of 2018. The previous owner, also a well regarded 928 enthusiast, commissioned significant reconditioning to #338 as detailed below. Prior to that #338 was located in Texas where in 2013 it received a good quality glass-out full respray in its original color. @Mrmerlin continued the reconditioning of #338 also detailed below. The air conditioning has been full sorted and blows very cold as shown in the instant-read thermometer photo in the gallery.
*Note: The transmission is difficult to shift into second gear when the car is cold and there is a rattling noise when the clutch pedal is released, but goes away when the clutch pedal is pushed in.
#338 exhibits several 1978 only features such stainless steel gas cap, battery box cover, small louver center vents and chrome door lock surrounds.
Also included with #338 are its Porsche Certificate of Authenticity, owner’s manuals, original spare tire, Webster spare tire compressor, jack with bag, tool kit with yellow screwdriver, OSRAM spare bulb kit, spare belt with tag, two spare spark plugs, tire changing gloves, first aid kit, two keys, two sets of floor mats and complete nine-volume Porsche 928 Workshop Manuals.
Recent work performed prior to current owner’s purchase:
  • Replaced timing belt, water pump, rebuilt tensioner, new tension arm roller, idler, bushings & bolt
  • Camshaft carrier reseal front & back, cam sprockets replaced
  • New fuel pump, feed hose, strainer & seal, fuel accumulator, fuel pump check valve, fuel filter
  • Replaced clutch, uprated release arm bushing, new throwout bearing, new clutch master & slave
  • Borla stainless steel cat-back exhaust with custom Y-pipe
  • Smog pump delete with correct fan belt tensioner and rear head plugs
  • EGR delete with correct 'Euro' r-side exhaust manifold and custom intake plenum block-off plate
  • Bosch Copper plugs, cap & rotor, Beru plug wires, and 'Green Wire'
  • Greg Brown Lifetime fuel feed & return hoses
  • New steel lower ball joints
  • New inner/outer tie rods, and Delrin rack bushings
  • Replaced shift lever bushings and front ball cup, rebuilt rear coupler
  • Replace coolant hoses and coolant flush
  • Brake fluid flush
  • Replace vacuum hoses,
  • Replace air filter & intake seal
  • New engine dampeners
  • Cleaned central electrics panel, new fuses, cleaned all ground points & 14-pin connector, new positive battery cable, new window switches
  • New front windshield.
  • New OE hood liners
  • Period-correct cold air intake tubes
  • Refinished phone dial wheels
  • Refurbish CV half shafts
  • Convert radio to Aux/Bluetooth and replace door speakes
Work performed under the current ownership by @MrMerlin:
All parts came from 928sRus (@ROG100) unless otherwise noted
  • Replace upper hood latch
  • Replace fuel tank sender unit, seal and strainer
  • Replace door vents (both sides)
  • Replace rear sun visors
  • Repair cigarette lighter
  • Fit all new door guides and new window felts
  • Replace coolant bottle
  • Reset injection & timing
  • Replace various vacuum lines
  • Replace L&R block off plates
  • Denso A/C compressor from Griffiths
  • Kuehl A/C barrier hoses from Griffiths
  • Greg Brown A/C high pressure line
  • Replaced expansion valve
  • Alignment
Other work performed under current ownership:
  • Four new Boge shocks from @ROG100 (928sRus)
  • Four new Michelin Pilot Sport A/S tires
  • Straighten rims, road force balance and nitrogen fill tires
  • Changed oil and filter: Sept 2018, Lucas 20W-50, Mahle filter, compression ring
  • Changed gear oil in transaxle: November 2018, Redline 75W-90NS
  • Fresh battery
https://photos.app.goo.gl/afmTLcSXdR1ADlZo2
TJsBeer is offline
Old 11-18-2018, 08:35 AM
TJsBeer
TJsBeer's Avatar
Not sure why some of the text in the ad is huge and some is small....not trying to shout anything out there
TJsBeer is offline
Old 11-18-2018, 10:29 AM
hlee96
hlee96's Avatar
This car needs a new home.
Maybe I will jump in!
Beautiful and worth much more than asking.
Good luck
hoi
hlee96 is offline
Old 11-18-2018, 10:49 AM
TJsBeer
TJsBeer's Avatar
Cold Start Video
TJsBeer is offline
Old 11-18-2018, 10:55 AM
TJsBeer
TJsBeer's Avatar
TJsBeer is offline
Old 11-18-2018, 01:36 PM
islaTurbine
islaTurbine's Avatar
Good luck
hoi
Hoi,
Please let me jump on this one. If not, will you sell me a Petrol/Cork 928?
#joking
#notjoking
islaTurbine is offline
Old 11-18-2018, 05:52 PM
hlee96
hlee96's Avatar
Talking
1st come (with cash) 1st served!
Ooooo, let's see who can open up their wallets faster.
I'm only 30 min drive from Jeff's house....
hlee96 is offline
Old 11-18-2018, 06:01 PM
islaTurbine
Old 11-19-2018, 02:17 PM
PorscheStrong
PorscheStrong's Avatar
I've seen this car in person and it's a fine car. Well spec'd and in great condition. Owner/seller is a true enthusiast. Buyer won't be disappointed.
PorscheStrong is offline
Old 11-19-2018, 03:34 PM
TJsBeer
TJsBeer's Avatar
[QUOTE=PorscheStrong;15441460]I've seen this car in person and it's a fine car. Well spec'd and in great condition. Owner/seller is a true enthusiast. Buyer won't be disappointed.[/QUOTE
Thanks Brad.
@islaTurbine has purchased #338.
Doug's getting a great car and he has given me first rights if he ever decides to sell her.
I know for sure this is going to be one of those "I never should've sold her" moments.
But, other opportunities beckon for now and life must move on.
TJsBeer is offline
Quick Reply: 1978 Porsche 928 (#338)
