964 Forum 1989-1994
need button caps for a/c, defrost & recirc
Old Feb 24, 2012 | 08:55 AM
Enso's Avatar
Enso
very helpful for me i'm missing the same *****
thanks for this info
glenn
Old Feb 24, 2012 | 10:11 AM
creaturecat's Avatar
creaturecat
Originally Posted by 911Jetta
Mine too! I was hoping I could just glue/tape it in place...now I know better.
Huge thanks for the DIY you created.
I used crazy glue. So far, 6 months later, all is well.
Old Feb 24, 2012 | 04:02 PM
Laker's Avatar
Laker
I tired crazy glue, at first it didn't hold. When the button's insides break away, there isn't much left besides an empty shell to glue to. After I did the replacement, on the old switch, I tried crazy glue again- this time I glued the switch up and 'off' whoops Maybe warm Fun-Tak inside the button would do a nice job of holding it in place, or something more commercial/permanent like caulk. I paid $144+tax for the double switch.
Old Feb 25, 2012 | 03:42 AM
RicardoD's Avatar
RicardoD
Great write up, my buttons need replacing on my C4, I love to figure out how to refinish the buttons
Old Feb 26, 2012 | 04:19 PM
stevepaa's Avatar
stevepaa
nice writeup
i pulled mine to find my klinking noise and decided to inspect that little fan, it was full of dust, the tube had dust in it and the probe was off center.
i cleaned the spindle with kleenex dampened with graphite spray and fan works quite nicely now.
thanks
Old Feb 26, 2012 | 09:27 PM
Laker's Avatar
Laker
Originally Posted by Laker
... I pulled off the air sampling fan at the rear, and blew out the cobwebs from the rubber tube that runs the length of the CCU......
yeah, it gets nasty in there
Old Feb 28, 2012 | 12:25 PM
Goughary's Avatar
Goughary
I just went to order part number: 944-653-921-00 and was told it's 129 dollars for the switch? Does that sound right? Am I ordering the wrong part? Sometimes I just cant understand how it's possible that they can charge that much for something so simple...
Old Feb 28, 2012 | 12:31 PM
GeorgeK's Avatar
GeorgeK
And you're lucky to find it so cheap. Costs much more in Europe.
Fine example of the factory supporting its air-cooled roots ... not.
Old Feb 28, 2012 | 01:20 PM
Laker's Avatar
Laker
Yeah I paid a little more, but do see it on Sonnen for that.
You have to make sure it's the exact same double (Defog/Recirculation) button as the CCUs varied slightly.
Anything 'fan' related is very expensive it would seem
Old Mar 20, 2012 | 11:24 AM
993James993's Avatar
993James993
Hi Laker,
How were you sure about the part number? Is it simply a matter of ordering the switch based on your car's model year?
Were the contacts simply pressed in? No soldering?
Thanks for the write up. I need to do this for both switches.
Old Mar 20, 2012 | 12:21 PM
Laker's Avatar
Laker
If your CCU has two buttons on the right, with the upper being recirculation and the lower being De-fog / De-frost windshield, it's the right part number. The single part contains both switches. (Re-circ & De-fog) They plug right into the green board (no soldering). You can see the slots on the right and left edges of the green board.
Old Mar 20, 2012 | 10:29 PM
993James993
Thanks Laker! Yesterday the switch cover fell off the main power button so now I need to order both switches. I'm tempted to look for a used CCU but it would likely have the same issue. I'll likely go to Sunset as they have always treated me good.
Old Mar 20, 2012 | 11:36 PM
dfinnegan's Avatar
dfinnegan
Wow, that part is now $130! Guess I should have bought back when it was only $68!
I'll just have to wait until it's *really* expensive :-)
Old Mar 21, 2012 | 03:12 AM
hamah's Avatar
hamah
Laker, you need to somehow get these DIYs you put together put in the DIY section so 10 years from now it's easy to find. How will I ever find this useful info under a subject "need button caps for a/c, defrost & recirc"? Thanks
Old Mar 21, 2012 | 10:57 AM
993James993
I concur. It took me forever to find this thread. The search function did not work and I later realized that by luck I had subscribed.
