997 GT2/GT3 Forum 2005-2012
2 Thousand 7 | GTY3
Old 03-31-2017, 08:06 PM
  #61
bmwtye
bmwtye's Avatar
Still need to add the writeup of the suspension install. But in the mean time here a couple full view pics of the car
Old 04-04-2017, 07:07 AM
  #62
jbigelow
jbigelow's Avatar
Beautiful Tye 😍
Old 05-04-2017, 09:07 PM
  #63
bmwtye
bmwtye's Avatar
Some say its worthless now, I say its Worthwhile!
Old 05-04-2017, 09:41 PM
  #64
ilko
Agent Orange
ilko's Avatar
Awesome!!
Old 05-05-2017, 11:45 AM
  #65
RAudi Driver
RAudi Driver's Avatar
Received 2,951 Likes on 1,747 Posts
Tye, I would take your car with 100k miles over many others I've seen. You've done a spectacular job on what has to be one of the nicest .1's on these forums.
Old 10-04-2017, 05:35 PM
  #66
bmwtye
bmwtye's Avatar
So decided to make some changes, JRZ have moved on to a new home. Next up:
Old 10-04-2017, 06:49 PM
  #67
pissedpuppy
pissedpuppy's Avatar
Originally Posted by blackbull
I give you "Moby Dick".....
uh, wow!
Old 10-04-2017, 07:02 PM
  #68
ngng
ngng's Avatar
really curious how the JRZs vs DSC feel!
Old 10-05-2017, 01:00 AM
  #69
JarmoL
JarmoL's Avatar
Very nice! I am secretely lusting after something similar.
Old 10-10-2017, 06:06 PM
  #70
bmwtye
bmwtye's Avatar
Working on installing the Cup Power steering pump, but want to maximize trunk space and not just mount it down in the trunk like everyone else does.
Initial fitment and measurements indicate this will work. Now working on designing a custom pump mount/battery tray and then will test fit.
Old 10-10-2017, 06:12 PM
  #71
ngng
ngng's Avatar
interesting location on the PS pump! how do you plan on routing the PS lines? are you planning on using a relay for the power, or the passenger side fuse block?
Old 10-10-2017, 06:21 PM
  #72
VID997
VID997's Avatar
Tye,
See attached image for reference, PS line diameters and expansion tank.
Old 10-10-2017, 06:37 PM
  #73
bmwtye
bmwtye's Avatar
Thanks guys, I def understand the line diameters and potential challenges of routing to the rack. Electrical wiring part is easy. Lets just say I won't be the first to have done this, as a well known Porsche tuner shop has done this multiple times and given me understanding of what to do.
Old 10-10-2017, 07:20 PM
  #74
shadowz
shadowz's Avatar
Unreal build, thanks for sharing, very complete and balanced for a great street/trackable car
Old 10-10-2017, 08:14 PM
  #75
bmwtye
bmwtye's Avatar
Obviously not the same pump, but you can get an idea of how there are a lot of different line choices that can be used which makes routing lines not as big of a challenge as it may initially appear. What matters with the lines is ID, PSI limits, and how vibration is handled.
Also take notice at the hole already in the body here that could serve as a line routing option (disregard circled part of picture I borrowed). Im talking about the hole towards where the steering shaft goes.
Quick Reply: 2 Thousand 7 | GTY3
