964 C4 light refurb
#841
#842
More parts have arrived. A new spoiler wall for the Silver car and a set of front diff driveshaft seals for both cars.
Before I reinstall the engine and transmission on the White car I'm going to replace one front driveshaft and replace all three diff seals and the diff mount rubber as there will never be an easier time to do it.
#843
Many months of work and now the self doubt sets in. Did I tighten every bolt. Will it leak? Is the timing correct. Unfortunately I won't find out for a month as I have to travel for work.
#845
#847
My front left axle nut didn't seem to be accepting the full 339 ft lb of torque so I ordered a new nut.
When I removed the nut I couldn't see anything obviously wrong with the shaft thread or the nut so I refitted it and managed to get it torqued correctly this time. Weird.
The other thing I noticed is that the new and old nuts are different lengths. While the new nut has a lock feature it looks a bit flimsy to take the full torque. Maybe it's just my lack of engineering knowledge.
#848
Originally Posted by John McM
Fan belt installed. The hex head bolt is only torqued to 10 Nm.
Krikit tool allows belt tension measurement. 25kg is correct for a cold used belt.
In your photo you would be less than 15kg.
If the instructions are wrong and you are supposed to read the gauge from the bottom of the black needle and your are at 25kg then my other thread was a total waste of time because my alt belt tension is correct.
#851
It probably doesn't matter one bit, John, and if I we're not right there doing the same thing I wouldn't have noticed....
On my car, the cylinder temp sensor plug is above the flywheel sensor plug.
#852
#853
John, I take it all back !
My car had them reversed !!! Wonder who did that?!
I'm looking in the FSM and the crank sensor is above the cylinder head temperature sensor. This is on page 10-103.
Sorry.
One more thing some mechanic did in the previous years this car was serviced...
Sorry.
#855
Sorry.
Sorry.
I'd rather have what I'm doing challenged than make a critical error.
BTW: I think we need to start a P fix it errata thread. The power steering pump PM along with questions over torque values need to be recorded somewhere.
