How many conductors or pins is it? PET has a list of electrical connectors in section 9. But some of the connectors are only available as part of the wire harness.
Actually, I *think* the single pin connector is available on PET, but there are several references, and I hope someone has gone through it already.
I only have one pin (actually the female half) that broke.
The female connector has an OD of 3.5mm. That is the one I need.
The corresponding male connector has an OD of 1.6mm.
Can't seem to find the corresponding part in PET (?)
Appears to be an off-the-shelf Molex connector, you should be able to find them at any electrical reseller. This appears very similar - check the gauge of the wiring (AWG) to confirm. More results here.
