New 79-81 flexible circuit board burned up
Alright, so I just installed my new PCB after the old one stopped working.
The gas gauge was pegged ( I know I don't have a full tank) and the warning lights had a split second delay before coming on.
Then the smoke came wafting out from under the dash.
All connectors were connected to the correct connection with both fully populated ones connected to the bottom connectors and the one missing some connections attached to the back.
Here are some pictures. Does anyone have any idea what could have happened?
Former Vendor
Yes.
Actually have had that happen, in the shop.
It's possible to install the bulb sockets so that they short directly over to the ground side, instead of the power going through the bulb. Burns up the power side of the trace to the bulb really fast.
I make sure the guys check the bulb sockets really carefully, before turning on the power, now.
dead short in the board? I hate those things. VW had, for a while, layers of them sandwiched together.
Car would act dead sometimes until you pressed on the stack and the panel would come alive.
Can you find the errant burn spot?
You can call me Otis
I may have a used one for sale after this weekend.
$120 + shipping for the whole cluster,
as is.
'79 Porsche 928 instrument cluster
'79 porsche 928 inst cluster pc
.....cue randyv
as is.
.....cue randyv
I'm saying screw it at this point and taking it to North Hollywood Speedometer to let the pros deal with it.
Will update when I install it.
Finally got the issue resolved for now.
$700 in new circuit boards and a $400 service by North Hollywood Speedometer which included all new bulbs bulbs (don't want to touch it for 37 more years) , rebuilding the speedometer motor, and recalibrating the damned thing and it should work.
I have the day off so I will fit it and hope for the best. All in all it cost me 3X as much as I thought it would have and I could have probably bought a new cluster from Porsche for that.
Eh, c'est la vie...
Eh, c'est la vie...
