power seat, mirrors and memory fix
Old Feb 18, 2013 | 04:09 PM
kingsmen11's Avatar
kingsmen11
Good work everybody.
Old Feb 18, 2013 | 05:58 PM
Tom in Austin's Avatar
Tom in Austin
Good post. Makes me wonder why my forward and backward switch sometimes goes to sleep ... do the switch instructions have to go through the controller board on the way to the motors? Worth it to flip the seat over and try reflowing the solder one nice spring day ... might even wake up the snoozing lumbar up and down adjustment ...
Old Feb 18, 2013 | 07:46 PM
ROG100's Avatar
ROG100
Basic Sponsor
Tom I guarantee that is the problem - all go through the memory box.
Old Feb 19, 2013 | 12:50 PM
Speedtoys's Avatar
Speedtoys
Fantastic. My seats either work fully, or not at all, independent of each other.
Pass seat on a warm day, drivers seat hasnt worked in a year+ at all, but used to only function on warm days as well.
Sitting in the sead oddly..to put pressure in some places more than others USED to work to a degree..reflowing solder makes sense.
Old Apr 14, 2017 | 02:52 AM
Ed Scherer's Avatar
Ed Scherer
I dealt with this same issue today, thinking it was a problem at a connector, but ultimately deciding it was likely bad solder joints in the power seat controller.
Symptoms were:
  1. Seat/mirror memory switch #1 backlighting worked only intermittently.
  2. Sometimes all three memory switch back-lights would turn off. I only realized yesterday that the power seat motors also were inoperative when this happened.
For the last few months, I suspected (due to the rule "what you touched last is probably what you broke") that symptom #1 above was due to something I messed up when doing the yellow #1/#2/#3 switch backlighting / incandescent memory switch backlighting -- to clear LED / red LED conversion. I had explored that a couple times before and found nothing.
Today, I spent a lot of time jiggling cables around (first with the seat in the car, and later with the seat removed) and couldn't pinpoint where the discontinuities were occurring. Finally, I noticed that just tapping the power seat control unit would cause the intermittent behavior to change (start working or stop working).
Did you know that the cable to the seat is just long enough to let you test it outside the car?
Got the power seat control unit (928.618.134.02) off the seat (disconnecting all the connectors takes a while!) and opened it up.
As you can see from above, connector #1 is for power and ground (terminals 30, 15, 31). Let's take a look at the solder joints for those pins:
Well, those are crappy solder joints! No wonder there was intermittent power loss!
Repaired those; here's the "after" photo:
And how about that intermittent backlighting on memory switch #1? Here's what the solder joints for the pins for connector #15 (which, with labels like "PL1", "PL2", "PL3", "PT", and "WL" sure looked likely to be related to the switch backlights; "PL1" is probably the switch #1 backlight, and that corresponds to the bottom right pad below) looked like:
Fixed those, too. Went ahead and re-flowed all the rest of the connector pin joints. Most of the rest didn't look so bad.
FWIW, I was using a temperature-controlled soldering iron at 750 °F and added just a little bit of old 60%/40% tin/lead solder (the latter based on the assumption that this old PCB was probably using similar solder) to each joint, mostly for the benefit of adding a little rosin to assist with flow.
IMHO, these PCBs were likely improperly manufactured.
Oh yeah... everything worked perfectly upon seat re-installation.
Old Dec 6, 2019 | 02:56 AM
Tony's Avatar
Tony
BUMP...
oh..this thread is spot on.
Goes hand in hand with the "just wanted to say" thread by BC.
Looky... Yikes...
Get your minds out of the gutter......
Old Dec 6, 2019 | 04:05 AM
Tony's Avatar
Tony
20 minutes with a magnifying glass and a basic 40w soldering iron with a cleaned tinned tip and it all works
This place rocks.....
Reflowed joints.....
Old Sep 24, 2023 | 09:32 PM
Myself's Avatar
Myself
Symptoms were:
This was perfect..Just read this and tried re-soldering...actually worked....kind of...passenger seat came out fine, everything works...drivers I only have memory function #2 working...any idea which plug it is that controls this so that I can focus on that one?
Know this is an old thread...just hope there is someone out there reading it..lol
