Journey of an Engine Replacement on 2002 996 w/Tiptronic
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0154_b14f4585ded6b99b60a007caf17f8b760d8e79e8.jpg)
Getting ready to remove the AC Compressor. This sensor needs to be removed to access the back rear bolt of the compressor.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0155_b944d422ebccf920e14a34dafb2dff4e6aa7518f.jpg)
This is the sensor, and there is a holding grommet that the sensor fits into. Remove this and with a little skill, you can remove the back right bolt.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0156_e6cefa50f9d0aea8abb499dce15aa18dbc63830d.jpg)
Front bolt...easy.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0157_94c092722cb6b5a78591a2d7c6a7d023dcb9805b.jpg)
Second bolt...easy.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0158_b2f2672c1a5a4fb52986239aa69c431358896cd5.jpg)
I put the first two bolts back in where they belong, after I removed the AC Compressor off the engine. I did not remove the compressor, so I don't have to have it recharged.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0161_1aaab6127290aff14f5742ef96b355a2023261fb.jpg)
Here is where the third bolt goes. Don't forget it, when you put the compressor back on. See the bolt that I replaced. Don't want to lose it.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0160_d52656931900ed55d7dcb002b392944b5dd0169b.jpg)
Taaa Daaa
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0163_55ba0aef595128ab6d0b8d6e7ece0105f2e50259.jpg)
Next...remove the engine connectors.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0164_f7c0f56224d6421cb3731655d4b6acd94ec374a1.jpg)
Sorry for the blurrrrrrrr. I hope these are keyed differently. I didn't keep track of which one went where.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0168_75df254b3d6e33bf420d092e3729f5a1cdd67f98.jpg)
Engine connectors disconnected.
Next, we will remove the coolant reservoir and the air pump in the corner.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
"Sorry for the blurrrrrrrr. I hope these are keyed differently. I didn't keep track of which one went where."
The plug with the fabric tape near the plug goes to the top socket!
Not bad observation...EXCEPT that is a picture of the engine I am taking OUT. The replacement engine so happens to have fabric tape on BOTH connectors. I compared the two connectors, and it appears that they are keyed a little differently. We cross that bridge when I get there.....
DOH! Hopefully the key is in the keying... Good luck
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0185_ed9462fbfea0eb3edc92ebc4671116d2041f825e.jpg)
The next step in Wayne's book discussed taking the fuel lines off the driver side fuel rail. Actually, there has been a change for 2002 and later. There is a different setup and only one quick disconnect. The fuel rail and hoses stay connected to the engine. I didn't find this out until it was almost too late, but luckily I checked the site and got some direction.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0169_29ed5fdbf3746dc6f1b27ec5b4be6fe6d39a96f2.jpg)
Starting to remove the coolant reservoir. Quite frankly, I should have tired to lower the engine first. I couldn't remove it without doing this. I wrestled with it for a while, before giving in an dropping the engine a little. Save time...start off. Also easier after I removed the secondary air pump. These pictues are out of order, because it was a trial and error thing.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0170_da7f29b119d0e289fea4c4655bea7957e4f6e850.jpg)
Removed hose....
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0171_d12cc7b436ac9621d7a04079fb5654aec55e3998.jpg)
Disconnectign secondary air pump. Notice the jar that was draining coolant, after I disconnected it from reservoir.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0172_1b8c495bd1079708cc1bacdc46a8032758451f3f.jpg)
Hose off....
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0173_e82e305b0242288d1d9b2e4966ca8260d5e62506.jpg)
Secondary air pump. Pretty easy to remove bolts holding it in....gives you a lot of room to remove coolant reservoir.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0174_329d242b3cb7405e715319759d3ee8923faae352.jpg)
Disconnect this plug....
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0175_06a52ed34c17a98cf3861c8866752b213950813b.jpg)
another view....
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0177_4dbe8c8b2e320fa9709e6d5d45ccc01a337ab0a1.jpg)
I believe that this is the quick disconnect connector (upper hose that connects to metal hose) for the fuel hose, that feeds BOTH fuel rails
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0178_f9ab98f3546a6c1d09f8760fe9a7616225cce6ac.jpg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0179_47f870387224489e573cd329fdf70afc90930b65.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0180_ad11eb47c08f63bc4b13a543b9838d516f27d4ff.jpg)
Removing another hose off of coolant reservoir.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0181_ce4bcec496678653719bc5f5a75fe23770977e2f.jpg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0182_dca013941d7249f72af9e7eb78f45cfa99ef9b9d.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0183_baab4b175e65f70885ac66426c3c7d6be2b73e85.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0184_65c37c88396e383c8d8572d759edb925f534b70f.jpg)
Just a quick note....I started off taking these pictures, simply to document how I needed to PUT IT BACK TOGETHER. I left a lot of these pictures here simply as a reference of how things looked as I was disassembling. Not all pictures are relevant to the disconnecting or removing of an item.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0192_a480c8fe377eb0f1e24b74f9eea7b92005d84ae9.jpg)
I jumped ahead and started removing a lot of the coolant lines. I was there anyway, and obviously they needed to come out at some point. Wayne covers this later in his book. There is a little metal clip that holds the hose on. Don't lose it.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0186_5ca32556f632339dfdf51ef564f9dc2be1957867.jpg)
Remove the clip and pull.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0187_991d055277ddddbddba00a4605984ac30f8d8e93.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0188_6bde63a1c6c2cedf160a589529b2f34004da9fc3.jpg)
Under the car...looking up.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0190_e7e7b25a7b5bfbfe0778edaa60912f1a25807cc0.jpg)
Passenger side cooling hose.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0191_3e1965759bd2f4725b9fdbf820ae105b662154b2.jpg)
I removed this set of hoses. This is how it sits, when it is in the car.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0193_e6583de7d265e2aa618b4d1fd18c712d8c386236.jpg)
Next we moved to removing the bumper cover, bumper, mufflers, and cats. This process is pretty straight forward and the book does a great job of walking you through it.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0194_563b7a975ebbf424f4b2018ac9a7427deecc75be.jpg)
Keep track of where all the screws go. Baggies, note cards, and black marker.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0195_0deb191c9f60f990ea1e03597858c7052bf66a06.jpg)
Kinda says it all....I didn't take pictuers of removing the bumper cover. A few screws, and carefully pull it away from the body, to prevent damage.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0196_970aea66866e69b01def79a521d1243cbcf8ca36.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0197_644c3c4fc5ed1721d132c4d8e874552b5ac1fa66.jpg)
Starting to remove the heat shields that surround the muffler. Again...easy.....
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0198_78aeac6136f0c8e52d633b5418821a55ce8641b2.jpg)
I made my son help me. Here is how it slides away from the body.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0199_9c88f3df680a681a7e020759a7bb18b95d81db42.jpg)
This is on the rear passenger side. I am sure that this is the air bag thing-a-ma-jiggy-bobby. Diaconnect and remove.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0200_62ea59777221434af2a8a358786d510b651502d1.jpg)
Again...simple stuff. Bumpers removed
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0206_e3276d16f481174e8dc624fdc59c91fab8b297ff.jpg)
Next...I climbed under the car and removed the plastic trays. Put all the bolts and nuts in a baggie.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0207_92dfbfed5f54430410ee910ac1ba4bf2677edbfc.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0203_b94a4f9348b1d6a9f17373fa5429fb2524a52fa9.jpg)
Moving on to removing some of the bracing under the car. All straight from the book.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0204_b29350ea2441e6dddfa3aa55ef524c53ba520899.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0202_e6098739573703ad249c9d39ea012eac66d2a184.jpg)
Again...a lot of these bolts I put back in the car, where they attach. Hard to lose them that way.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0205_c98f6f787bfb225523ce5a4bd940dad17b01ada6.jpg)
Removing CV shafts. IMPORTANT....get the right driver to remove these, or you WILL strip them out. I believe it is a triple square??? NOT a TORX....
I actually ordered new CV bolts, just to make sure I didn't have any other issues. The metal is soft and replacements are CHEAP compared to the hassle of trying to remove a stripped one.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0209_4fd6d51880413c5990a4a37a8700691fb087d771.jpg)
Removing rear sway bar
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0208_6196b7378b777b5aabd9a7730472558cd022c69e.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0210_d56fc8e6664b45f7170f856354bed5e13e551347.jpg)
More stuff to disconnect. I noted how the wires were run and tucked in.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0211_ad3f23231b458978dbc20201ce57214af612bfd7.jpg)
How the wires were tucked in for future reference.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0213_bfa206f158ba1a0e8f84adb04c283ce781a761ff.jpg)
Mufflers removed and removing the O2 Sensors. Notice where the blue one and black one go.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0214_ef75238226062dcce4ff6fd236d700a69bbd72e2.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0215_131cc248fbe49675cc827b8d5e07f771f98777a0.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0216_4639ada3e8c47037172bba7c465d1fb3eaa34cad.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1600x1200/img_0212_07c0fc3721b63efa3677a47caa0bbcee7b00daa7.jpg)
O2 connector.
