951 Fender "Turbo" Decal
Old 03-31-2017, 10:24 PM
Bmuldoon
Bmuldoon's Avatar
Default 951 Fender "Turbo" Decal
Just purchased the "Turbo" script fender decal for my 951 from Suncoast Porsche Parts. After I opened the package I noticed that it's an "Avery Dennison" decal with the correct gradient design and includes a sticker with the Porsche part number. Can anyone confirm if this is the original part or a reproduction? I thought I read somewhere that the OEM sticker came with a placement guide etc. Maybe I'm overthinking it but for $78 figured I'd check with the group. *The Amazon.com sticker is due to the fact that I paid through my Amazon account number.
IF it is the correct part, any advice for correct placement on the fender?
Thanks!
https://www.suncoastparts.com/product/95155922100.html
Old 03-31-2017, 10:46 PM
MAGK944
MAGK944's Avatar
Part number comes up correct on PET.
Old 04-01-2017, 02:53 AM
2zeroes
2zeroes's Avatar
The one I received a couple months ago says "scotchcal film 3m" on the back with a placement guide. This is for a black turbo decal.
Old 04-01-2017, 04:03 AM
beamishnz
beamishnz's Avatar
I bought a silver and a black one about a year ago and neither had placement guides. If anyone has a placement guide I'd be interested to see it.
Old 04-01-2017, 07:21 PM
Bmuldoon
Bmuldoon's Avatar
Installed it today. Definitely a few bubbles that should go away over the next couple of weeks.
Also replaced my silver crest center caps with "turbo" script. Turbo overkill?
Old 04-01-2017, 11:12 PM
beamishnz
beamishnz's Avatar
Looks great! Not so sure about the turbo centre caps .. but I'm a purist
Old 04-02-2017, 06:43 PM
boost feen
boost feen's Avatar
The placement guide is just the way the oem 3M sticker is cut at the factory it has a curve cut into it to follow the fenders bow out and the hood line is straight cut so you can align right where it needs to go, you pull the backing off and use liberal soapy water spray to apply it to cleaned wax removed fender then use small squeeze to remove bubbles once happy on location you carefully peel back the paper membrane that's made to get wet and squeegee over and then do a final squeegee to make sure all bubbles are out. Let cure for 24hrs and fully dry before doing any major speeds or messing with car.
Old 04-03-2017, 08:56 AM
slownrusty
slownrusty's Avatar
Timely! I just bought the same decal and installed it this past Saturday:
Old 04-03-2017, 03:41 PM
beamishnz
beamishnz's Avatar
Originally Posted by boost feen
The placement guide is just the way the oem 3M sticker is cut at the factory it has a curve cut into it to follow the fenders .
Thanks for that ... now I understand what is meant by a position guide.
Quick Reply: 951 Fender "Turbo" Decal
