944 2.5 8V Race car #55
Old 07-30-2016, 03:20 AM
  #91
mattipuh
mattipuh's Avatar
Some project pics from our intake made by local magican Kenaxbillet.
Shiny!
Old 07-30-2016, 11:48 AM
  #92
Noahs944
Noahs944's Avatar
WOW Matti! You ARE going supercharged aren't you? Daaaammmmmnnn that's beautiful fabrication.
You know I'll be watching your posts, big fan from Canada, eh?
Old 07-30-2016, 02:19 PM
  #93
mattipuh
mattipuh's Avatar
Cheers Noahs944!
Yes, we will fiddle SC in, cannot wait firsts tests.
Some additional work with brakes aswell as we had to let the brake booster go.
Old 07-31-2016, 12:40 PM
  #94
Noahs944
Noahs944's Avatar
I just talked with a BMW owner who did a Ford v8 transplant and had to let the booster go, he then installed a power steering pump hydraulic booster, and says it's incredible.
Old 03-13-2017, 05:06 AM
  #95
mattipuh
mattipuh's Avatar
Car is slowly getting ready. Managed to build intake piping & IC setup. Still missing MBLV, fuel rail, fuel piping, brake lines, MAP sensor, fuel pump + wiring... etc.. but not too far anymore..!
new SC setup + piping
Bulkheads for fuel, brakes and clutch
Noahs944 (01-23-2021)
Old 03-13-2017, 07:35 AM
  #96
ealoken
ealoken's Avatar
Nice car, looks fast
Old 03-13-2017, 09:04 AM
  #97
mattipuh
mattipuh's Avatar
Thanks, ealoken, hopefully it will not be slower with SC :fingerscrossed:
we'll see what it delivers..
Old 03-13-2017, 09:07 AM
  #98
mattipuh
mattipuh's Avatar
has anoyne experience running RE85 fuels and aluminum connectors in their fuel line? Read somewhere it wouldn't be a good combination, but then again - some say it's not a problem. go figure...
Old 03-13-2017, 09:21 AM
  #99
ealoken
ealoken's Avatar
We use one 100 and on 10 mico filter in Norway, but Race E85 does not have all the addhesive as pump E85, so it`s less sluggish.
Old 03-13-2017, 09:57 AM
  #100
mattipuh
mattipuh's Avatar
ok. planning to use 250micron before pump an 10 micro after. just wondering the corrosion of aluminium..
Old 03-13-2017, 10:01 AM
  #101
ealoken
ealoken's Avatar
It depends on the quality on the pipes.
I have bought and used alot of pipes from Fittings of norway, i belive they are selling Fragola pipes.
Old 03-13-2017, 03:42 PM
  #102
mattipuh
mattipuh's Avatar
Im using teflon for piping. Checked that alu connectors should be ok with re85..
Old 03-17-2017, 12:00 AM
  #103
Tiger03447
Tiger03447's Avatar
Noah..that's called a hydroboost system down here in the lower 48. Used on lots of trucks, like Ford F350's (1 ton and larger)..gets rid of the vacuum booster but has a lot more piping involved. .02 cents Thanks.
Old 03-23-2017, 04:46 PM
  #104
mattipuh
mattipuh's Avatar
Cannot wait to get the car dynoed - targetting +280hp...
Old 05-17-2017, 05:06 AM
  #105
mattipuh
mattipuh's Avatar
damn, some issues with belt slipping. need to figure out some tricks as SC kit is made for car with AC. have some ideas what to test next... Seems that it takes longer than planned what is common when doing new stuff..
Quick Reply: 944 2.5 8V Race car #55
