Crazy vibration on interior.
Old 02-05-2017 | 11:01 AM
dnwong's Avatar
dnwong
Default Crazy vibration on interior.
https://youtu.be/H22hg6cSja0
i have this crazy interior vibration sound on the right side of car near the front of the door when acceleration at low speeds. Sound goes away at higher rpms?
Thoughts?
Old 02-05-2017 | 12:58 PM
Dougs951S's Avatar
Dougs951S
video wouldnt load. my blind guess is motor mount.
Old 02-05-2017 | 01:03 PM
fwb42's Avatar
fwb42
Check your heat shields for the exhaust around the cat. to see if they have come loose.
Old 02-05-2017 | 01:18 PM
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
motamounts.
Old 02-05-2017 | 07:35 PM
AkechiMotors's Avatar
AkechiMotors
Does it present at idle but disappears above 1500k or so? Motor mounts.
Old 02-05-2017 | 09:51 PM
MAGK944's Avatar
MAGK944
Its hard to tell from your video what is causing that sound. Is it just a virbrating sound or are you feeling actual vibration? Is it happening only while you are moving or when you are also just stationary with the engine revving? Has the vibration always been there or did it happen after you did some work like changing the balance belt?
I embedded the video below for those that said they couldn't see it.
Old 02-06-2017 | 12:57 AM
dnwong's Avatar
dnwong
It is mostly a sound. It happens at low rpm after you start accelerating. It starts at a certain RPM like ~1200 and goes to ~2000. No noise when idling and stopped. The vibration has been around for while. Just starting to try to sort it out.
It sounds like its coming from the A pillar somewhere (but could be the door).
Old 02-06-2017 | 04:04 AM
FRporscheman's Avatar
FRporscheman
Maybe the plastic rain tray came loose and is rattling? Or else something else is rattling in the battery tray? Get a friend to drive while you sit in the passenger seat and prod around to see if you can feel the vibration. Or maybe by touching an area you can stop the rattle (and thus locate it).
Rattles on my cars have always been heat shields (around the cat, below the headers, etc).
Old 02-07-2017 | 12:39 AM
i944's Avatar
i944
I had a vibration sound that turned out to be the corner of my hood tapping the body. Hood adjustment and proper placement of the rubber damper in the fender channel fixed it.
Old 02-07-2017 | 01:14 PM
dnwong's Avatar
dnwong
Cats gone.
Old 02-07-2017 | 01:17 PM
dnwong's Avatar
dnwong
UPDATE:
I went out and listened some more and the sound does appear while reving the engine at idle too. Not as loud or noticeable and I can also feel the vibration a little.
How can I tell is motor mounts are bad?
Old 02-07-2017 | 03:00 PM
MAGK944's Avatar
MAGK944
UPDATE:...How can I tell is motor mounts are bad?
You can measure them in-situ:
Old 02-09-2017 | 11:37 AM
dnwong's Avatar
dnwong
So, I measured the height of the right mount and it looks like ~60mm. Don't see any substantial cracks in the rubber.
Old 02-09-2017 | 04:40 PM
Jfrahm's Avatar
Jfrahm
So now you know.
Quick Reply: Crazy vibration on interior.
