Year: 1996 Make: Porsche Model: 911 Cont. Porsche Models: 993 Mileage (numbers only please): 57300 Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control Color: Polar Silver VIN:WP0AA2991TS323321 Price (no $ sign please): $53000 Private or Dealer Listing: Private Listing Location (Region): SouthEast Body Style: Coupe Transmission Type: Manual - 6 speed 2 or 4 Wheel Drive?: 2 Wheel Drive Engine Type: Fuel Injection Stereo System: AM-FM CD
I am the second owner of this 1996 Porsche 993 C2 which I bought from the original owner in 2013 in California. It has approx 57k miles. It is the polar silver with a black interior and overall, is in excellent condition. It drives perfectly, everything works as it should. There are no check engine lights. It has never been smoked in.
The car comes with a set of Twin Turbo 18" wheels as well as a set of the original 17” Cup II's. Both sets have Continental Contisports DW’s with plenty of thread.
It doesn’t drip any oil. I have the engine tray removed currently as my shop says it helps with cooling. The tray comes with all the other original parts of the car.
It was in a small accident in 2006 whereby a pedestrian in FL walked out in front of the car. The car was traveling slowly but the hood and windshield had to be replaced and the bumper was resprayed. I have all the receipts for this and all receipts from new for all service and work performed over the cars 21 year lifespan. It is quite a stack of paper. I had the original paintcode stickers reproduced for the underside of the new hood.
The car has been garage kept for its entire life. Apart from a few road trips, it has never spent a night out on the street. It has never been tracked or autocrossed. Any questions please feel free to contact me whenever and I will get back as soon as I can.
Since I bought the car I have…
Installed BergvillFX HID's. Replaced the battery, headlight lens, brakes (discs and pads, front and back), tires, seals, belts, rotors and distributor cap. Replaced the A/C evaporator and had the CCU rebuilt by BergvilleFX. Replaced factory suspension with Koni FSD system and M033 springs. I had a 50-State legal UV window film Installed. The front bumperettes have been removed and the rear-bumperettes painted. I installed a set of Rennline pedals and Rennline Door-pulls. I replaced the factory radio with Pioneer DEH-X9500BHS with bluetooth and replaced all the speakers. The microphone is wired to discretely sit at the top of the drivers A-pillar. I have the original factory radio as well as all the other original parts that have been removed. This includes the original factory foglights which have been replaced with the Twin-Turbo duct with LED parking lights. All the interior and exterior lights have been replaced with LED’s including the 3rd brake light and the rear fog-light position was also wired for an additional brake light for extra visibility. The gasket between the front bumper and the body has been replaced. The handbrake surround and cassette holder have been replaced with a leather-covered version and a leather-covered cup holder. Various oxygen sensors, ballasts and relays have been replaced as needed which is all detailed in the breakdown below the option guide. The car is wired with an easy-connect directly to the battery to make it convenient to attach to a battery maintainer. Both key original key fobs have been replaced for the much nicer key-ring type.
All servicing has been performed yearly at European Performance in Cary, NC. The car is incredibly reliable and starts up whenever needed and it doesn’t generate smoke when it does. It doesn’t burn oil and everything feels tight. It is a perfect daily driver if you are lucky enough to live in that type of climate or it is a perfect garage queen if you don’t(I don't). The exterior is in excellent condition and apart from a few paint chips on the front of the car which is to be expected due to its height off the ground, it needs nothing. The interior is immaculate. The front seats have a few light creases in the bolsters but are otherwise also in remarkable condition. The rear seats look like they’ve never been sat on(probably haven't). The car comes with all of its original manuals, compressor and tools.
Vehicle Identification No. WP0AA2991TS323321
Model Designation CARR. COUP
Model 1996
Order Type 993330
Engine code M64.23
Transmission code G50.20
I218
I233
I323
I426
I434
I912
M032 Touring suspension
M058 Impact absorbers, front and rear
M130 Control and indications in English lettering
M197 Stronger battery
M220 Locking differential 40 %
M224 Automatic limited slip differential
M288 Headlamp washer
M329 Radio Blaupunkt Toronto SQR 48
Radio "Porsche CR-210" USA
M335 Automatic seat belt, 3-point,
rear
M338 Rear-wheel drive
M379 Standard seat, left,
electrical vertical adjustment
M380 Standard seat, right,
electrcal vertical adjustment
M398 Cup wheel, 17-inch
M423 Holder for cassettes and coins
M441 Radio preparation
M445 Silver wheel centres with
full-colour Porsche Crest
M454 Automatic speed control
M455 Anti-theft device for wheels
M480 6-speed manual transmission
M484 Version for USA
M493 Narrow bodywork
M530 Anti-drive-off feature -96
Anti-drive-off feature 433 MHz 97-
M534 Theft security system
M544 Tank of 75 litres
M553 Version for USA, Canada
M562 Airbag, driver's side and front passenger's side
M566 Front fog lights, white
M567 Windscreen tinted, upper part
darker coloured
M573 Air conditioner
M576 Without rear fog lamp
M599 Roof cover molding
M602 Raised stop lamp
M650 Electrical sliding roof
M651 Electric window opener
M657 Power assisted steering
M660 obd 2
M685 Rear seats, split
M975 Luggage compartment lining
with velour carpet
01/23/97 00, 216 Car Purchased new from Desert European Motorcars in Rancho Mirage, CA. The original MSRP was $68,452 (I have the original window sticker).
01/08/99 11,371 15k service inc Oil Change and all filters replaced. Clutch pedal switch adjusted. Cruise control problem fixed. Washer pump replaced.
10/01/99 12,206 Airbag light problem fixed.
01/09/04 17,849 Yearly maintenance inc Oil Change and all filters replaced. Replaced both rear toe arms. Fan resistor for A/C condenser replaced. Replaced all belts and update alternator pulley.
04/20/05 22,258 Loose airbag sensor replaced. Car hesitation diagnostic, brake fluid reservoir cleaned out, lines bled to unit and all brakes bled.
11/07/05 29,166 30k service. The invoice is missing for this service but there is a dealer's stamp in the service book which refers to it. When I called Reeves Porsche in Tampa, Florida, they told me that the software has changed in the intervening years and they can’t send me a copy of the invoice but that they can see which parts were used and these are indicative of a full 30k service including Oil Change, All filters including pollen filter, brake flush, spark plugs and all belts changed. The total cost of the service was just over $1700.
01/24/06 30,858 Car involved in an accident with a pedestrian who walked out onto the road directly into the car. The car was travelling at roughly 15mph and the pedestrian damaged the front bumper cover, the bonnet, the windscreen and the front part of the roof. The windscreen was replaced and all panels were repaired and resprayed. The driver was found to be not at fault for the accident. The car was repaired at Gene Perez Body Repairs in Tampa, FL. The work was completed on 02/22/06 and the bill came to a total of $5721.69
09/01/11 Mileage unknown. Battery replaced.
01/06/12 40,097 15k service inc all filters. Brake flush, clutch flush, Replacement key reprogrammed. Replaced micro switch on steering column lock. Speedo repaired. Windshield washer pump replaced. Front and rear lid struts replaced. Replaced 3 drive belts. Evacuated and recharged A/C system. Warm engine Intermittent starting problems was resolved.
11/21/12 41,215 Failed emission inspection.
01/26/13 41,931 Replaced cylinder head temp sensor.
01/31/13 42,008 Passed emission inspection.
02/19/13 42,319 Engine air duct replaced, A/C Head Unit replaced, Refrigerant refilled, Chain gasket covers replaced, Oil changed and filters replaced. Spoiler wall replaced. Some cosmetic items replaced inc seat hinge covers and wiper arm caps.
04/06/13 42,405 Car purchased in San Diego by me and driven to Raleigh, NC.
05/29/13 45,708 Front brake Rotors, Pads and sensors replaced. Shifter Shaft Seal replaced. Gear oil flushed and replaced. Replaced Distributor Caps and Rotors. Replaced DME Relay. Replaced all tires with Continental Contisport DW’s. Converted Headlights to HD Xenon. Removed cassette holder and replaced with leather rear cup holders and replaced plastic trim around the handbrake with aftermarket leather surround.
11/30/13 47,651 Added ½ Quart of Mobil 15/50 Synthetic oil.
12/21/13 47,820 Replaced headunit with Pioneer DEH-X9500BHS Single Din In-Dash CD/MP3 Receiver and speakers with Polk Audio DB461 and DXi525 speakers. Installed LLumar Air-80 window tint on side and rear windows.
2/21/14 48,144 Oil and filter change. 10 liters 5w40 Mobil Synthetic oil. Removed Mass Air Flow Sensor and Idle Control Valve. Cleaned and reinstalled ISV. Replace MAFS to fix P0150 code (O2 Sensor Pre Cat, Bank 2, Signal Implausible). Cleared code. Rear spoiler drive lubricated and missing right side windshield wiper bump stop was replaced. All work performed by European Performance.
4/1/14 48,441 Koni FSD suspension with Porsche M033 springs installed and one rear shock mount replaced by European Performance.
4/6/14 48,654 Passed NC State inspection which was performed at European Performance.
5/3/14 48,875 Replaced the rear series resistor (964-616-550-02) and the temperature sensor (964-659-120-00) and tested the rear fan to ensure that it now works as intended. All A/C issues have now been resolved.
10/21/14 50,755 Added ½ Quart of Mobil Synthetic 10/40 oil.
01/12/15 51,650 Added ½ Quart of Mobil Synthetic 10/40 oil. Replaced front head-light lenses, replaced front parking bulbs, indicator bulbs and all rear bulbs with LED’s and replaced foglights with Turbo Ducts and LED positioning lights. Removed front bumperettes and had some minor cosmetic work done on the front bumper cover.
03/17/15 51,972 Oil and filter change. 10 liters 15w50 Mobil Synthetic oil. Replace upper and lower driver side valve cover gaskets. Relay replaced for front oil-cooler fan. Replaced battery vent pipe. NC State inspection. All work performed by European Performance apart from relay.
4/15/15 52,000 Added additional LED Brake-lights as well as a 3rd LED Brake-light strip and a pad-keeper to fix sagging engine insulation.
1/18/16 54,542 Added Rennline Door pulls and Runline pedals.
4/22/16 Replaced Evaporator core and both A/C and oil cooler ballast resistors. Replaced beading between body and front bumper cover.
4/25/16 CCU rebuilt by Tore in Norway at BergvilleFX.
5/21/16 Fixed Door pockets with reinforcements I designed myself.
Yeah, it's a great color. Blue in some lights, pure silver in others. It's a great car. Wish I used it more. I spent so much time getting it just right including designing and building the bumperette deletes and door pocket reinforcements that when I ran out of things to do, I moved on body and soul to another project.
Sorry to see you're selling I remember when you first got the car and drove it back to NC.
GLWS, What's next?
Not sure. Either something that's less usable and therefore easy to leave in the garage or something that's super-usable that I don't care about the way I care about the 993.
..and an indoor car cover from California Car Covers and spare relays, window switches, the original bulbs and various other bits and pieces from my ownership of the car.
GLWS, What's next?
My Dad says that he is willing to fly over from Ireland if we need to deliver the car back to the West Coast. I explained that it's not quite how things work and he seemed disappointed
