the stock 991.2 tips have the larger inlet pipe like the 997.2 (S) and 991.1 (S)
so if you buy tips, make sure not to get 997.1/2 or 991.1 base tips.
i think base used to be like 2.25 and S 2.5, i know this cause i swapped my 991.2 base tips out and had the larger diameter pipe which made using 997.2 S tips work perfectly.
Thanks Matt We've got them alright! You can find them here on our website for $695 a set, available in a Polished Chrome or Black Chrome. Shoot me a PM if interested, forum members do get a discount on our products
Polished Chrome
Black Chrome
Have you guys solved your rainbow discoloration issues yet, after these are heat cycled?
Thanks, just wanted to ask you if They go out that far out of the rear, or can They be instales farther inside?
A little over a year ago we had bad batch, we have since switched to a very high quality PVD coating that we have had no finish issues with. A couple of the guys in the back took a blow torch to one once with no ill effect, although i'd not recommend doing that haha. The PVD tip finish is warrantied for a full year, plenty of time to put them through the paces
We provide some adjustment in and out on the tips as well as up down left right. I cannot say how much more movement over the picture as the vehicle is not longer at the shop to review
I have the Fabspeed chrome tips on my 991.2 and they tuck in quite nice. Same as stock.
Thanks man,
no one ever mentions it, but I have been afraid of them, because if they arrived and they stuck out as much as they look on their site, I would have to throw them to the garbage.
But if they can be adjusted a bit, like you say, they must be good.
