964 Forum 1989-1994
Need some advice on top engine mayor service
Old 01-09-2017, 01:39 PM
MA7008O
MA7008O's Avatar
Default Need some advice on top engine mayor service
Hi there,
Car is a 1991 C2 cabrio with just 147.069 kms. Runs perfect, no issues, no oil leaks, no need to do any special repairs up to date except maintenance. No track or modifications, just driven around about 400 kms a week, mainly on highways.
While doing a routine maintenance, I notice “something” while taking out one spark plug: a piece of one head stud and its nut. Sparkplug of cylinder 2.
I would like to list what I’m are my plans and know what you think about it:
  • Drop engine.
  • Disassemble up to the cylinders.
  • Change:
  • 24 head stud (have yet to decide between OEM 993.101.170.53 or the ARP ones – big $$ difference).
  • 24 nuts.
  • Oil pressure and temperature sensors on engine.
  • Piston rings.
  • Clutch (just the disk), slave cylinder and hose.
  • Engine Bay Sound Proofing Damping Mat.
  • All gaskets involved.
  • Mayor service (I was doing it anyway).
  • Clean, check, paint, …. all around engine bay.
Am I missing something?
Any advice will be much appreciated.
Thanks!!!
Old 01-09-2017, 02:50 PM
JohnK964
JohnK964's Avatar
I used a set of Supertec head studs when I replaced my studs came with all the hardware
Old 01-09-2017, 03:21 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
You have a good list. Also inspect all of your rubber hoses (oil, vent & fuel), CV boots and engine mounts. When I last dropped my engine, I discovered a fuel line on the back of the engine had swelled up like a balloon and we about to burst.
Old 01-09-2017, 03:27 PM
MA7008O
MA7008O's Avatar
Thanks, I'll check tehm out.
Old 01-09-2017, 03:30 PM
MA7008O
MA7008O's Avatar
Thanks.
Yes, I’m planning on looking everithing up, and hopefully it will.
Summer 2015 I did some work which involved engine mounts, minor oil leaks (distribution and valve covers and some other leaks), power steering, and CV boots.
Let see what I find!!!
MA7008O
MA7008O's Avatar
By the way, it's my first engine drop......
Old 01-09-2017, 04:26 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Best of luck on the engine drop. Its a bit scary but once you do it, its not that bad in hindsight. Just take careful notes as you go and the reassembly will be easy. I had a friend help me and we did it. Let us know if you have any questions or need moral support.
Old 01-09-2017, 04:40 PM
JohnK964
JohnK964's Avatar
Pull the rear bumper makes it easier to get car high enough to get engine out from under the car 😀Ask me how I know this
Old 01-09-2017, 04:45 PM
964Andrew
964Andrew's Avatar
+1 for inspecting all oil lines. Also, Porsche OE top end rebuild kit covers a lot of necessary gaskets and hardware. Be careful not to fall in to bottomless pit of "While you are there"
Pfixit has an extensive library of rebuild videos that I found helpful when I was doing mine.
http://www.pfixit.com/
Shop manuals are absolutely necessary.
Porsche 964 Parts Catalog
https://www.dropbox.com/sh/awe6hcujn...lCsGcyR9a?dl=0
Porsche 964 Service Manual
https://www.dropbox.com/sh/8apzzxglp...N158wiWNa?dl=0
Thanks!
Andrew
Old 01-09-2017, 04:59 PM
JohnK964
JohnK964's Avatar
If you plan on removing the pistons fro the rods get the tool to help install the circ clips
Old 01-10-2017, 04:12 AM
4th911
4th911's Avatar
I would get a full set of Head and Sump Gasket sets..much cheaper than getting them as and when you need them.
As mentioned earlier, I would change all washers when I check all hoses both metal and rubber.
If you intend to take out the rocker arms etc...you can't put it back without an oil leak unless you install a set of rocker arm seals ...I just learned the hard way...
http://type911shop.co.uk/epages/de86.../Products/1693
Old 01-10-2017, 06:36 AM
MA7008O
MA7008O's Avatar
Thanks all of you for the ideas and support, very mush appreciated.
@964Andrew: any link to those kits? I just found the ones for the gaskets, which I will get.
@JohnK964; not planning on removing the pistons.
@4th911: not planning on removing rocker arms, but if so I will change the gaskets, which are included on the kits.
And definitely, I will check all hoses, cables, ….
Thanks again!!!
Old 01-10-2017, 09:46 AM
JohnK964
JohnK964's Avatar
Thanks again!!!
Rocker seals won't be in a gasket kit. They are cheap in my mind a good investment not all that tuff to install and would give you a chance to inspect the rockers and the shafts. don't forget a narrow ring compressor there ain't much room below the cylinders when reinstalling the cylinders.
Old 01-10-2017, 10:43 AM
MA7008O
MA7008O's Avatar
Thanks.
I will update my list.
Old 01-10-2017, 12:52 PM
964Andrew
964Andrew's Avatar
OEM Rebuild Kits
Bottom end - 930.100.901.04
Top end - 964.100.902.00
If you are not splitting the case you only need the top end. You. An get the kits directly from the dealer or many places online. Obviously there are many, many more parts you should consider replacing or rebuilding depending on their condition upon disassembly.
Thanks!
Andrew
Quick Reply: Need some advice on top engine mayor service
