rpm specific fuel cut
Old 12-25-2016, 06:55 PM
moalaska
moalaska's Avatar
Default rpm specific fuel cut
Im having issue with what seems an rpm specific fuel cut
At about 3k rpms afr goes high to 16 and starts bogging bucking, 1/3 throttle or worse
Symptoms seem similar to bad tps but dont think its tps
Afrs spot on idle and no load cruising
Fpr set to 45 psi, but when warmed up pressure dropped has to readjust
Tried unplugging o2 sensor, same symptoms
Unplug tps, same symptoms just worse
Raise fuel pressure a little, symptoms still there
Adjust maf piping
Run dedicated power and ground to maf
Set idle per procedure
New fuel filter, check valve, spark plugs, newer cap rotor
Replaced ref and position sensors
Running msd blaster coil with ballast resistor
Resolsered dme within last year, cleaned all grounds as well
Could it be fuel pump going out
Maybe tps is flaky
Bad dme or injector drivers?
Thoughts
Old 12-25-2016, 07:25 PM
Humboldtgrin
Humboldtgrin's Avatar
I would start on the fuel pressure first. When was the fuel filter replaced? Have you checked the hard lines to make sure there not pinched? Is the timing belt installed correctly?
Old 12-25-2016, 07:43 PM
moalaska
moalaska's Avatar
Fuel filter replaced within last couple hundred miles along with fuel check valve and cleaned tank screen. Haven't checked hard lines. Timing belt done within last couple hundred miles as well with rollers and balance belt and timing marks line up.
Old 12-26-2016, 12:07 AM
NCLA951
NCLA951's Avatar
Having similar issue, mine is worse when cold. Have to nurse it along if I give it too much throttle it will bog but if I baby it I can get around. Entirely new fuel system and flow checked. When I get back from Xmas holiday I'm going to install the new ref/speed sensors and harness and see what happens.
Please post if you figure yours out!
Old 12-26-2016, 03:06 AM
Humboldtgrin
you need to check the fuel pressure when that is happening.
Old 12-26-2016, 04:44 AM
moalaska
moalaska's Avatar
Kind of hard to check Fuel pressure while driving but i agree that would be nice to know.
Old 12-26-2016, 05:43 AM
MAGK944
MAGK944's Avatar
Have you checked you vacuum lines?
Old 12-26-2016, 11:22 AM
moalaska
moalaska's Avatar
Ive redone all the vacuum lines ill double check though.
Old 12-27-2016, 07:15 PM
rlm328
rlm328's Avatar
Check your IC piping connections, sometimes the silicon hose that connects them will pop off. You may want to use T-Bolt clamps downstream of the turbo.
Old 01-01-2017, 07:54 PM
moalaska
moalaska's Avatar
Ok so just installed the mercedes fuel pump in the 944. So far my fuel system is all updated, pump, filter, check valve replaced tank screen cleaned. Aftermarket fpr with check valve installed after fuel rail and before reg. 54# injectors from vts. Still having issues. At about 2800 rpms, at light throttle cruising, afrs go to 16-17, with stumbling. Pulled the plugs to look at them. They have about 50 miles on them. Not really sure where to check from here. I haven't changed my spark wires yet, maybe at that specific rpm range they arent working good. Rotor and cap are New. Im about to go crazy and order a vems system then i can see what all my sensor outputs are doing.
Old 01-01-2017, 08:12 PM
moalaska
moalaska's Avatar
Ok decided to check timing. Set crank at tdc looked through bellhousing hole ot in middle of hole. What's wrong with this??
Old 01-01-2017, 08:32 PM
moalaska
moalaska's Avatar
Nevermind. Rotated it again and its spot on.
Old 01-01-2017, 08:38 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Are you sure the motor is at TDC #1 on the compression/combustion stroke? From the position of the rotor, you may need to rotate the motor one full revolution to get it where you want it, to confirm the cam mark lines up.
Edit: Posts crossed, you got it.
Old 01-01-2017, 08:54 PM
Tom M'Guinn
Bad wires are a notorious source of stumbling under load. If you aren't confident in yours, I'd change them. If you feather the throttle, can you get the RPMs up above 3k, or does it cut out at 3k no matter how soft you are on the throttle? If it cuts out at 3k no matter what, then you might double check the TPS idle switch at the DME, including the wiring and DME, to see if the DME is seeing a closed throttle and refusing to deliver fuel. If you can feather it gently up the RPM range, then weak ignition is a possibility.
Looks like a lot of rigmarole on the fuel lines/damper/fpr. What are you trying to accomplish with all that, and are you sure you are not creating issues you could avoid with a good old Bosch 3 Bar FPR on the rail?
Do you have the MoMonitor for your Vitesse system? It let's you monitor and log most of the engine sensors/vitals while driving.
Have you checked the solder joints in the KLR? Have access to a spare DME and KLR you can try?
Old 01-01-2017, 08:56 PM
moalaska
moalaska's Avatar
Another question
I did google search and found results for 911s but not 944. I decided to check my rotor for continuity since it was off. Found that it doesn't have clean continuity there is resistance, so either rotor has built in resistor or its bad. I know spark plug boots have built in resistance too. Do i have wrong rotor seems weird that there would be resistance in rotor and boots, but maybe they put resistor in rotor to reduce chance of arcing inside the cap or something.
Quick Reply: rpm specific fuel cut
