widest tire on a 21" GTS rim
Old 12-13-2016, 03:38 PM
8202632's Avatar
Default widest tire on a 21" GTS rim
anyone ventured into a wider tire size from the standard 295/35/21 size?
Old 12-13-2016, 05:08 PM
1BadAction
1BadAction's Avatar
I wouldn't. Even one size wider you're out of the recommended width range of the tire since 295s already run big on 10" wide wheels themselves. It would work, but its never really a good idea to go against the ranges the tire manufacturers state.
Old 12-14-2016, 07:53 AM
Petza914
Petza914's Avatar
Received 6,600 Likes on 4,197 Posts
Google wheel width tire size chart and you'll get pics of charts that show the possible and ideal tire widths for each wheel widths.
Going wider also means the aspect ratio needs to change on order to keep the rolling circumference the same, which doesn't really happen until you get to a 315 width tire with 30 aspect, which is much too wide for a 10" wheel. Best to stay with what you have. On my widebody I'm going to a 22"x12" wheel with a 315/30-22 tire, but that won't fit under the normal bodywork and there are very few tire choices available in that size.
Old 10-13-2019, 12:33 PM
Nasher
Nasher's Avatar
you can now get the original P7 again.
https://www.lucasclassictires.com/24...4-2454516L.htm
so these will ride better than anything else
Quick Reply: widest tire on a 21" GTS rim
