I am considering purchasing a 2016 used Cayenne Turbo only thing I don't like are the wheels it seems to have the standard 19 inch wheels that at least in my opinion a pretty sad-looking compared to the 21 inch wheels my question is can I upgrade to the 21 inch wheels on this vehicle I guess I don't want to interfere with the TPS anti-lock brake system wheel bolt pattern throwing off the speedometer with bigger Wheels just wondering if all this will bolt up without any issues if I consider to do this all imput greatly appreciate it thank you
Yes, there is no limit to the wheels available in the aftermarket, though to be honest most turbos have 20 or 21"s so I'd keep looking as there are plenty of cars out there.
8.5 x 19 are typical for the winter tire rims on a Cayenne. The computer in the vehicle will allow selecting 19 x 8.5, 20 x 9 or 9.5" and 21 x 10" rims along with a number of tire sizes on them.
With each successive wheel size you go up, you'll reduce sidewall height (tire aspect ratio) comparatively to keep the rolling circumference the same. Any OEM pairing should do this, but if you're looking at aftermsrket wheels or non-standard tire sizes, if you go to www.willtheyfit.com and enter your current setup and what you're considering, it will compare them for you.
Bolt pattern is 5,x130 with a 71.6mm center bore on all Porsches, except the Macan, which uses a 5x112.
In a couple months, I'll have the 21"x10" wheels from my '09 Turbo S for sale, if that's a style your interested in. As part of my widebody build I'm moving to a 22". Depending on where you live, maybe mount up some snows on the current 19s.
