Garrett GTX-R genII turbos.
Professional Hoon
Looks like Garrett has launched a revised series of the GTX series. The GenII
https://turbobygarrett.com/turbobygarrett/turbochargers
GTX3076R GenII
GT3076R VS GTX3076R
And also check out the new GTX3584RS
GT3582R vs GTX3582R
GTX3076R GenII
GT3076R VS GTX3076R
GT3582R vs GTX3582R
Professional Hoon
They do make the GTX3582R GenII in reverse though. But i don't think the upgrade would be worth another 50Lb/min on the compressor map.
For each new Gen 2 compressor wheel it looks like they sacrificed efficiency over the corresponding Gen 1 compressor wheel just to stretch the compressor map a bit further to the right edge... Not sure I get the point.
I spent quite a few hours on my recent vacation looking into this turbo.
Just a week ago I was set on a EFR9180 with Tial housing but now a GTX3584RS seems like the natural choice
...and also sweared a bit when I saw it won't come in reverse rotation
Professional Hoon
7163 will be nice, except no twin scroll.
7064 is the bigger frame, flows less but has a twin scroll.
7670 will flow what i need it to flow and has a twin scroll 1.05 But it might be to big.
I know the gtx3071R will be capible to flow enough and spooling up nicely.
On goes the reserch. again.
LOL
Professional Hoon
As far as i looked at them. The only difference in regards to the turbo is the compressor. Everything else is the same.
Performance wise, no idea. IMO minimal gains, unless you're at the turbos limit and you could use some more air with out compromising the size of the turbo.
Except the GTX3584RS. I think that's a great addition to the turbo line.
I usually wait for Perrin Performance to do a back to back test as they like to do with a fair amount of turbos. and being similar size engines you can sort of have a feel on what'll happen.
But ATP Turbo offers the 3584RS with their own turbine housing that is a 100% direct replacement with the Tial housings. Should be a very good 850-900 hp turbo.
That's very useful feedback. I guess they are not casted with the same high quaility metal as the OEM stuff. Tial housings work fine and I'm sure the Garrett "Ni-resist" SS housings work good too.
