Could I get some opinions on this timing belt noise?
Old 10-16-2016, 01:46 PM
odonnell
odonnell's Avatar
Default Could I get some opinions on this timing belt noise?
Replaced all rollers, water pump, timing belt (of course) and installed a cam timing advance key. No balance shafts as you can see in the video. I set the tension using the latest Arnnworx tool, and didn't have any issues with it - tension seems reasonable.
Does this match any tell-tale culprits, to you very experienced 944 wrenchers? It sounds like a bearing to me but am curious to hear what others think. It sounds like a supercharger whine (almost... a little quieter and more ghetto sounding) starting just under 3k RPM. Under the hood, it was much more pronounced, and after shooting this video I threw it into the garage and killed it,
Old 10-16-2016, 01:54 PM
Van
Van's Avatar
Is your balance shaft belt too tight?
Old 10-16-2016, 01:59 PM
odonnell
odonnell's Avatar
Tension is set to 0, doesn't exist on this car
Which is why I'm worried. If I had a balance shaft setup and it made this noise, I wouldn't think anything of it because that's fairly normal.
Old 10-16-2016, 02:04 PM
V2Rocket
V2Rocket's Avatar
Did you turn the timing belt tensioner roller the wrong way, pushing the timing belt teeth into the belt guard?
Old 10-16-2016, 02:50 PM
odonnell
odonnell's Avatar
Old 10-16-2016, 03:19 PM
KVDR
KVDR's Avatar
... maybe just a noisy new belt?
Sounds exactly like mine did when cold for the first ~1000 miles.
Old 10-16-2016, 03:41 PM
968workaholic
968workaholic's Avatar
How easily can you spin the water pump pulley? Sounds like it may be slipping and causing the noise imo. What belt did you use?
Old 10-16-2016, 04:26 PM
944Ross
944Ross's Avatar
Have you run it with the belt guards on? Is it still audible?
What DIS system are you running?? Mighty strange to see it running with no distributor cap!
Old 10-16-2016, 06:44 PM
odonnell
odonnell's Avatar
Maybe - I'll back off the tension a hair and just let it settle in. Everything has been done by the book so far.
The water pump is hard to spin by hand but will spin a little. This leads me to believe I'm a little on the tight side, which was intentional to account for belt break-in. That's probably the issue. Belt is a Contitech, I had the same product on the car for 3.5 years previously and it's still supple and in overall good shape.
I haven't run it with the guards on, although on my last timing belt I ran it with just the inner cover. The fact that I can hear it inside the car leads me to think it's abnormal from just a timing belt.
Re: ignition
They're LS1 coils running in wasted spark, via a MegaSquirt (Microsquirt to be specific). In the video, you can sort of see the crank trigger and the AFM delete setup w/ GM IAT sensor haha.
Old 10-19-2016, 01:12 PM
odonnell
odonnell's Avatar
Ok, now I'm second guessing myself on the belt tension. I set it using the Arnnworx tool, and I'm unable to spin the water pump by hand. That seems to be the other "rule of thumb" test passed around in addition to the 90* twist method. I've done belts before and usually I can spin it by hand.
WP is new and is not seized...it spins freely with less tension on the belt. Maybe the belt just has more grip on the water pump due to its material, and I'm worrying about nothing? I'm only concerned because of the whining noises earlier, but every other method of determining a good tension in checked off.
Old 10-19-2016, 01:31 PM
V2Rocket
V2Rocket's Avatar
I've never been able to spin the WP pulley by hand with the belt set at 90* twist.
Never figured how people got that one.
Old 10-19-2016, 01:44 PM
odonnell
odonnell's Avatar
Ok, thanks for the sanity check. I'll set it one last time and just run it.
Old 10-19-2016, 03:00 PM
marc abrams
marc abrams's Avatar
Mike, my car also whined like that also after I replaced the belts and rollers. I used the ArnnWorx 920x also. After a 100 mile drive the whine was about half of what it was. After 500 miles there's almost no whine when hot. I used Continental's belt and roller kit. I hope this makes you feel better.
Old 10-19-2016, 09:37 PM
AZ520
AZ520's Avatar
I know this sound, its the t-belt rubbing on the belt guard, the one right above the water pump pulley.
Old 10-19-2016, 11:40 PM
odonnell
odonnell's Avatar
Thanks Marc, I'll keep that in mind.
AZ250, I don't believe this to be the case. I painted the belt guard for this reason (to tell me if there was contact under any circumstances) and there is no scuffing. With the engine off, there is at least 1/8" gap, and the idler doesn't push the belt span closer.
Quick Reply: Could I get some opinions on this timing belt noise?
