Coffins and Wishbones
I have searched but cannot find a thread on rear suspension overhaul or specifically rear wishbones and coffin arm replacement. I was half through tracking the car after new tyres and the tech found the rear adjusters were seized solid and the rubber was twisting if he used force. I wondered how hard it was to over haul the rear track control arms. This is still a 98 C2. Anyone done a thread on this or got any word or pictures.
Thanks
Thanks
It's all relatively easy. When you say rear adjusters, what are you referring to? What problem are you trying to address?
I would upgrade the components in this order. As you go down the list it becomes less relevant which one to do first:
1. Track Tires Front and Rear (NT01 or equivalent)
2. Rear Toe Link (#13) - This one is essential to get a decent track alignment, especially if the car is lowered.
2. Coilovers (front and rear of course)
3. Sway Bars
4. Adjustable Upper control arms (#8)
5. GT3 Lower Control arm (#21)
6. Torque arm - #17 (though this will get you the least bang in the rear, but adjustables on the front have value).
3. Sway Bars
Thanks Slakker - The tyre (tire) place was trying set up the tracking and the rear bolts - I think it was part 22 (but could have been 15) in your diagram - were seized in the bush and it was not adjusting / not possible to adjust, so it will be camber adjustment they were trying to do I assume. If I can swap the bits myself they will happily finish off the tracking and charge me once. If I get the indy to do it It will be tracked by the Indy and I will have to pay for what was done at the tyre shop so double whammy - it looks straightforward if I can get the bolts out!
I will have a look on the Pelican and see if it helps Thanks. Normally about 1000 vids on you tube - not one I can find on this subject!
#15 is an eccentric bolt with a groove in it and a washer with a point that rides in the groove. You have to loosen from the nut side. I bet he tried to loosen the bolt and bound it up with the washer. You will need to get the nut loose first and then work to get the washer lined back up.
I bet when you get it off you will find where the "tooth" in the picture below is digging a channel through the threads on the bolt instead of riding in the slot.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Should have that here: http://www.pelicanparts.com/techarti...htm#suspension.
Thanks
