996 Turbo Forum 1999-2005
Critical - Maintain your Turbo Actuators
Old 09-27-2016, 01:59 PM
Richard.
Richard.'s Avatar
Default Critical - Maintain your Turbo Actuators
This is a part (YES the one which looks a little like a DV valve with the rod attached to the turbo) needs to be well maintained with WD40 as it can rust and cause all sorts of engine problems which you may think are boost leak or MAF related, Just solved a full turbo power issue with my car
911user (03-22-2022)
Old 09-27-2016, 03:52 PM
jumper5836
jumper5836's Avatar
Is this easy to get at, and photo of the location?
Old 09-27-2016, 06:01 PM
Ck986
Ck986's Avatar
Can you tell us new to Turbo cars how to properly maintain the Watergate actuators? The actuator rods are attached to the turbos behind the rear wheels.
Old 09-27-2016, 07:46 PM
993GT
993GT's Avatar
they are 'maintenance free' like any turbo car...just more susceptible to corrosion if winter(salt) driven due to their proximity to the road spray
best 'maintenance' for your wastegates is to drive the car hard and get those wastegate cycling very frequently
Old 09-27-2016, 07:59 PM
"02996ttx50
"02996ttx50's Avatar
i've also had wg actuator issues. it's confusing as the symptoms mirror boost leaks, failing/dirty mafs etc.
but they do get out of whack.. or rusted, 'tis true.
Old 09-27-2016, 08:54 PM
Ck986
Ck986's Avatar
So what part of the Watergate are you lubricating with wd40? Is the wg rod supposed to move easily by hand? Never had a turbo car before this and realize this can be a problem given the location of the turbos.
Old 09-28-2016, 12:17 AM
fpb111
fpb111's Avatar
The "Tricky Richards" On your WATERGATES need to be lubed with $$$.
The actuator rods on the WASTEGATE could be lubed with Water Displacement 40 (WD40).
They look similar to the piece with the black hose running to the center:
Old 09-28-2016, 01:28 AM
Atrox
Atrox's Avatar
Where are you lubricating?
Old 09-28-2016, 11:34 AM
jeanmarcboilard
jeanmarcboilard's Avatar
You would want to lubricate the "hinge" at the turbine housing, where it needs to move back and forth.
The following 2 users liked this post by jeanmarcboilard:
911user (03-22-2022), 997ttc (08-17-2021)
Old 09-28-2016, 01:05 PM
Richard.
Richard.'s Avatar
EXACTLY !!! is my MAF broken, do I have a boost leak, why is my car stuttering on full throttle, NO it's simply non lubricated turbo actuator valves .....
Old 09-28-2016, 02:37 PM
Third-Reef
Third-Reef's Avatar
The actuator itself has nothing to lubricate in it. It is an elastomer diaphragm with a rod attached to it. The pivot at the turbo (where the adjusting nuts are) runs in in the 200 to 500 deg. F range, make sure to use the high temp WD40. The real reason for binding most of the time is things not being aligned properly when the nuts are tightened down. When adjusting the cracking pressure for the actuators it should be easy to move the rods/actuators through their travel. It should be fairly smooth and not have the little pivot block on the end of the rod cocked and binding. Trying to check for binding while the actuators are exerting their full spring pressure on the rods is essentially impossible.
Old 09-28-2016, 03:30 PM
wross996tt
wross996tt's Avatar
Hmmmm yeah there is nothing to lubricate. Yes they can become corroded and out of adjustment...WD40 is NOT a lubricant FWIW, it is a solvent (quite the opposite) and may dissolve certain contaminants like rust.
Old 09-28-2016, 04:04 PM
Richard.
Richard.'s Avatar
Rust; of which there is often plenty here
Old 09-28-2016, 04:15 PM
jeanmarcboilard
What you said about the high temp is true, wd40 would burn off. High temp grease would work. Some drivers never get on the boost and the pivot point is never exercised and can seize. Checking for movement on the actuator rod is actually quite easy. Disconnect the hose to the actuator and use a mityvac or compressed air to move it.
Old 09-28-2016, 05:12 PM
Richard.
Richard.'s Avatar
All I can say its made a massive difference to my TT for circa $5
Quick Reply: Critical - Maintain your Turbo Actuators
