SCCA FP Cayman S
Old 08-21-2016, 12:24 PM
Grantsfo
Grantsfo's Avatar
Weighed the car today. With 1/4 tank of gas it's 2640 lbs. so is probably sitting at 2625 lbs at race weight right now. ...Sort of amazing to me as the car is street legal if I pop headlights back in and still has full stock dash with airbags, front carpets, passenger seat, stereo amps etc, AC, stock rear hatch, all rear heat shielding etc. I may bring it down to 2400 lbs and then ballast on passenger side to get better corner weights with my 280 lbs sitting in drivers seat. Don't think I will get that done by Nationals but will be plan for next season.
Old 08-21-2016, 05:10 PM
Grantsfo
Grantsfo's Avatar
Old 08-21-2016, 08:09 PM
mopar bob
mopar bob's Avatar
Originally Posted by Grantsfo
I don't know what to think of Hoosier measurements as I measure more tread than they indicate between 255 and 285.
OK as a tenth sounded like a small increase to me. When I was putting my Re71rs on yesterday for today race I tried me rears on the front to see how they would fit with -1.2 of camber. Lets say that they stuck out a bit and was about 1/4" from the strut. They are 285 30 18 and yes a different tire with not much neg. camber.
Old 08-22-2016, 03:10 PM
XPC5
XPC5's Avatar
That's wonderfully light. Looking forward to seeing the car run.
Old 08-26-2016, 11:45 PM
Grantsfo
Grantsfo's Avatar
22 lbs off the back end with Getty hatch! Passenger seat, mount and harnesses out too. At 2575 lbs now. That's just under FP weight minimum.
Old 08-29-2016, 08:22 PM
Grantsfo
Grantsfo's Avatar
Im going to take risk and try to fit 315 rear and 285 front week before Nats and test at event. I know its not recommended but car needs more tire.
Old 08-31-2016, 12:44 PM
Grantsfo
Grantsfo's Avatar
wow! 315 is so much bigger! This will be fun. Baseball bat at the ready.
Old 08-31-2016, 03:18 PM
XPC5
XPC5's Avatar
Slot the rear upper strut mount holes, that will help pull the top of the tire in.
Old 09-01-2016, 09:20 PM
Grantsfo
Grantsfo's Avatar
Oh yeah! 315 and 285 tucking under stock fenders.
Old 09-02-2016, 12:26 AM
mopar bob
mopar bob's Avatar
Oh I so love the Polizei look you have going. Do you think that the front tires will rub? I would like to hear back on that and did you roll the inner fender lip?
Old 09-02-2016, 12:40 AM
Grantsfo
Grantsfo's Avatar
Front 285 have a ton of room. I did flatten inner lip a little but it wasn't needed. Rear is tighter clearance.
Old 09-03-2016, 03:01 PM
mopar bob
mopar bob's Avatar
So you are running 18 x 9 in the front but at what offset? Is that a custom wheel or off the shelf? And how much negative camber do you need to fit the tire? You can PM me if you like.
Old 09-15-2016, 03:22 PM
Grantsfo
Grantsfo's Avatar
Well Nationals were interesting. Car was OK. Had some minor clutch issues that caused some misshifts into 2nd gear. Car was bit nervous in rear which forced me to drive conservatively. Tall gearing was no help out of slow turns. Overall my driving sucked but car was OK for new build.
My drive out was a nightmare. Truck broke down 175 miles from Lincoln on Sunday night. Paid a tow truck drive to tow my trailer to Lincoln. Dealer fixed truck and all was good for tow home to California.
I think next will be 16x12 inch wheels and slicks. Bump redline a little. Work on suspension setup. Think I need more front bar little less rear.
Old 09-16-2016, 03:21 PM
Grantsfo
Grantsfo's Avatar
Sorry dont know off hand as Jongbloed makes these wheels for spec Cayman crowd. I didn't even have to spec wheel for him. I run about -3 upfront and about 2.25 rear. However Id clear with -1 upfront. Remember I have coil overs with camber plates so I have more inbound clearance than a stock car.
Old 09-16-2016, 03:37 PM
mopar bob
mopar bob's Avatar
Thank you for the input. I will be running Ohlins next year to run in ASP so it's looking good. I'm planning for now.
Quick Reply: SCCA FP Cayman S
