Couple of new owner questions
I got a 997.2 TTS cab recently and it's a great car. I have a couple of questions though:
- when I accelerate and let off or shift up around 3-4K rpm there is sometimes a gentle metal scratching sound coming from the back. Usually less than half a second. It's not all the time and not easy to reproduce, but if it's a transmission or engine issue I'd like to take care of it before CPO runs out. Normal? Is it the turbo spooling down or something like that?
- I can't figure out how to show the boost pressure gauge. What's the secret?
- Passenger seat sometimes triggers the check seat adjustment/airbag warning. I've checked under the seat and it's clear. It's very intermittent. Take to dealer? Some other secret?
Race Director
I'm not looking forward to having the wiring problem traced down.
My best advice is to know how to reproduce the behavior/noise and take the car in. You paid for a CPO. Use it.
If the 997 Turbo is like my 996 Turbo the boost can be called up using the OBC stalk. I think I move the stalk up or down to cycle through boost, outside temperature, range in miles to empty, and something else.
Now you might have to work your way to the menu to select boost and remove something else though. Been too long ago I can't recall but I kind of remember playing with that shortly after I got the car and then have never touched it since. I'd have to refer to the owners manual I think to remember how to do this.
The Boost Pressure Indicator can be selected by using the lower left stalk and while observing the display on the lower portion of the tachometer, either press downward or upward (not forward or towards you) to cycle through, Navigation, Tire Pressure, Fuel Milage, etc.. until you see a "0" ....BINGO that's it!!!
Hope this helps. "LugNut"
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/660x695/latest_internet_trend_dogs_with_eyebrows_1_7f1b99d2a0de3ae6136c15ecd86df15c7c4a1851.jpg)
