944 SCCA XP build
Old 08-17-2016, 10:40 AM
  #46
kniners
kniners's Avatar
Not able to complete this project for the 2016 season without making concessions. I did not.
These two sidelined the progress...
Old 08-17-2016, 10:47 AM
  #47
kniners
kniners's Avatar
Back in the saddle. Should be able to stay on this project through completion now. Fingers crossed.
The wiring...
No I'm not an electrical engineer but it will get the job done. Some redundancy in case of a failure, quick circuit change and back in business.
Old 08-17-2016, 10:50 AM
  #48
kniners
kniners's Avatar
Transaxle and CV axles installed along with VSS sensor for the GM PCM.
Old 08-17-2016, 10:53 AM
  #49
kniners
kniners's Avatar
A few undercarriage shots...
Old 08-17-2016, 10:56 AM
  #50
kniners
kniners's Avatar
Cooling system going in, looks like my tape measure was working when I fab'd this up. whew.
Old 08-17-2016, 10:59 AM
  #51
kniners
kniners's Avatar
A couple shots of the interior with harness and guide bar installed.
Old 08-17-2016, 11:08 AM
  #52
kniners
kniners's Avatar
FAST Throttle body and cold air ducting install. Trying to stack much of the weight on the passenger side of the car to offset driver weight. You will notice the cooling overflow tank tucked in between the strut tower and engine. The P.S. tank will also remain in that area in the stock location.
Old 08-17-2016, 11:12 AM
  #53
kniners
kniners's Avatar
Using Tarret hollow front and rear sway bars. Here is the rear going on the car.
Special thanks to LINDSEY RACING for the great products and service!
Old 08-17-2016, 11:23 AM
  #54
kniners
kniners's Avatar
Here is a special project. Production of my own proprietary 3-piece wheel. Cutting from 6061 t6 Aluminum. Each billet piece weighs 51lbs. before machining. The goal is 9lbs. when complete.
I am having Titanium hardware manufactured for the wheels currently.
The front wheel will be 18x12 and the rear 18x13.5. Using Hoosier A7's 335 & 345 respectively.
Old 08-17-2016, 11:27 AM
  #55
kniners
kniners's Avatar
A few more pictures of the wheel center prototype in production and it's test fitment before continuing machining.
Old 08-17-2016, 04:21 PM
  #56
Grantsfo
Grantsfo's Avatar
Thats just sick! Im so jealous!
Old 08-18-2016, 07:52 PM
  #57
Earlydays
Earlydays's Avatar
.....loving the quality of the workmanship!!
Old 08-18-2016, 08:51 PM
  #58
mopar bob
mopar bob's Avatar
+1
Who could say more
Old 10-22-2016, 09:04 PM
  #59
kniners
kniners's Avatar
Completed hydroboost system.
Old 10-22-2016, 09:12 PM
  #60
kniners
kniners's Avatar
Aero work....
Mocking up rear wing before paint.
Angle of attack adjustable.
Yes, I am designing all of these goodies and enjoying every minute. I plan to tunnel the radiator and intake air over the winter.
Quick Reply: 944 SCCA XP build
