I did my first track day last week and the old girl held together.
My biggest complaint is I couldn't rev match because the two are just too far apart with the gas pedal being much lower than the brake. I'm tall (6'4") but have enough room to move.
Besides the expensive Rennline option are there any other devices or ideas others have done to solve the issue?
What shoes are you wearing? On the street in my regular sneakers I use the left side of my foot on the brake, and roll the right side to the gas for blips. On the track with driving shoes on I have started getting comfortable doing a traditional heel/toe. The skinny shoe and heavier brake pedal application lines everything up perfectly. It is possible being your first track day you weren't using the full extension of brake pedal, so things didn't line up.
But to answer your basic question, there may be other options for pedals but the rennline kit is the most popular.
To answer you both:
I have to do more of a toe-toe where the left most of my foot is on the brake and I roll the right onto the gas during the shift.
When I was standing on the brakes a couple times I really tried and the gas pedal was just too far away from the brake to even reach. I wear a 11.5-12 shoe so maybe I'm just too tall/big to do it properly.
Maybe all I need to do is get the pedal side extension to narrow the gap?
That's how i heel/toe on the street, most likely since you're getting full travel on the pedal you'd be able to do a traditional heel/toe. With the car stopped or off see how your foot fits with standing on the brake and trying to tap the gas with your heel. I was never able to do that on the street, on the track it only took a few laps to get it working.
I have small feet and use the same technique in the video. I have attached waffle pattern plates to pedals with the throttle offset to the left. This narrows the gap to make it much easier for heal toe. When threshold braking I want the ball of my foot on the brake pedal for feel/modulation.
It's just a question of getting used to it ... there is a big difference in feel between my 911 and the 944 !
I heel and toe everything i drive , be it my Mazda 3 or my son's Subaru Impreza,takes a little practice but you'll get it !
On a 44 you can adjust the brake pedal to line up with the gas pedal when on full brake. This will help you be able to just roll your foot almost on the same plane to get the blip.
I have 13 narrow feet and have no problems getting a good heel toe downshift.
To answer you both:
Thanks for the links.
I also have the Rennline pedal, it is a good upgrade when you get to it. I maybe unusual but I do not try to heel/toe under heavy braking. I tend to shift at the end of the braking cycle which takes a smaller blip to match.
I normally do not brake with the transmission as the clutch in these cars are a PITA to change.
I use a modified version of the video as I do not use the clutch when I hit the brake all the time. Depending on speed and the corner.
Interesting as that's what I was trying to do in the end. I just wasn't getting used to it enough to be able to get it down to 2nd in time at the end of the straight. It doesn't like going 3rd to 2nd all that much so I ended up doing most of the track in 3rd and 4th gear...that's a whole other issue I am dealing with and not the context of this thread.
I did see a post about adjusting the brake pedal down a little. Thanks to all who have posted! I love learning about all this.
