Did the job this past Sunday. Turned out I needed one more bit-set, a hex-bit set, which I was able to get at O'Reilly's. You need that to remove the lower brake-line bracket. The left front took me a couple of hours as it was a 1st for me. The right took only 45 min.
The pads came out very easily, once spread.
Hardest part was getting the left rotor off. Must have pounded on it for 20 minutes. Almost gave up. Right rotor was much easier to get off.
