CTT 08 Front Caliper - brake job
Old 04-15-2016, 12:47 PM
Wheel Dynamics
Former Vendor
Wheel Dynamics's Avatar
Close-up photos.....
see more at www.wheeldynamics.com
On the Porsche
Stripped, you can see access to the bottom in order to get the pads out
After refinishing
Close-up
Installed back on the Porsche
Old 05-03-2016, 09:02 AM
babaron
2nd Gear
babaron's Avatar
Did the job this past Sunday. Turned out I needed one more bit-set, a hex-bit set, which I was able to get at O'Reilly's. You need that to remove the lower brake-line bracket. The left front took me a couple of hours as it was a 1st for me. The right took only 45 min.
The pads came out very easily, once spread.
Hardest part was getting the left rotor off. Must have pounded on it for 20 minutes. Almost gave up. Right rotor was much easier to get off.
Thanks for all the help!
Ron
Quick Reply: CTT 08 Front Caliper - brake job
