1978 5sp #107 just arrived - aka the restoration of Minerva
#1006
Archive Gatekeeper
Sorry, forgot to address the fender edge beading question- Short answer is that it's the original stuff from the car, just cleaned up. Is the sealing strap on the PET diagram (801-25) that beading material, or is it the strip-caulk stuff that seals the fender to the body?
I can take better measurements if the dimensions would be helpful to find a replicate.
![](https://webfiles.uci.edu/redwards/public/Minerva%20engine%20compartment%20fender%20beading%20length%20123%20cm%202-22-16.jpg)
#1007
#1008
Speaking of which- we decided to swap condensers back to the proper early round-tube style. Mark brought a couple candidates last night, all are subtly different. Two bare aluminum and one painted black. The two aluminum ones differ in the aluminum channel riveted to the top- one is 'U' shaped (like a cap), while the other is 'S' shaped, the forward lip of the channel points down and the rear points up.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1136x853/20160401_210827_38948ad887156920b4e03ce479686247624c521b.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1107x830/20160401_210950_71bb12957cf3ba21b2163a0a7e717bd8cdc2903b.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1102x827/20160401_210958_113a225ec4a6cf74344e3d158c02dc9e176ee8e0.jpg)
You guys are going to owe me a new car cover...I've about wore the thing out taking it on and off for photo shoots...lol.
Brian.
#1010
Archive Gatekeeper
Aha! That's what the clips on the condenser mounts are for. Thanks Brian! ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Alex, here are the dims on the beading. It's out there somewhere!
Height:
![](https://webfiles.uci.edu/redwards/public/Minerva%20fender%20beading%20height%2013%20mm%204-1-16.jpg)
Width:
![](https://webfiles.uci.edu/redwards/public/Minerva%20fender%20beading%20width%208-3%20mm%204-1-16.jpg)
Channel depth:
![](https://webfiles.uci.edu/redwards/public/Minerva%20fender%20beading%20channel%20dpeth%2010-9%20mm%204-1-16.jpg)
Ribs per inch:
![](https://webfiles.uci.edu/redwards/public/Minerva%20fender%20beading%20ribs%20per%20inch%204-1-16.jpg)
Ribs per cm:
Height:
Width:
Channel depth:
Ribs per inch:
Ribs per cm:
![](https://webfiles.uci.edu/redwards/public/Minerva%20fender%20beading%20ribs%20per%20cm%204-1-16.jpg)
#1012
Archive Gatekeeper
![](https://webfiles.uci.edu/redwards/public/Minerva%20rear%20hatch%20trim%20installed%204-1-16.jpg)
#1013
And Rob - thanks: You are the man! This project is making me very motivated!
#1015
Google images says bare aluminum is correct for '78. Not sure about the 'lip'.
So, fellow 78'ers, what is the shape of the top shield/channel piece on your condensers- 'U' or 'S'?
<img src="https://tiq6qg.bn1301.livefilestore.com/y3mbYczx2euxnmfvlebc8e32MG2wnOGAj5BwIw80EztM-eRQYOWAAEhXJ3Ig2MqaaAeIGCOivuyTFnb6QoE04x3BYEJc8ZkjOdQXiZIlEDxjYrGaHIYux DDeQ3iWTXHO42aDfsUnnsnJyP2q8SDd9bUwg?width=660&height=495&cropmode=none" width="660" height="495" />
<img src="https://ti9fig.bn1301.livefilestore.com/y3mexk7fFLz4yATUdibKItUwVGpZ9j-86zt0i3GlAunUNzA1dzZPVfNIm4Uc4FkbkPp-0XkjgVK0Y2dq6Uf4TWyqWbiTB8DE80S6FCUg-9X6-ciseRqZo-sWPfbzq-_b7SClAaD-p3-BFuZRzxG3hS-_Q?width=660&height=495&cropmode=none" width="660" height="495" />
#1016
I'm amazed that you got the beading off Minerva without destroying it, and then were able to recondition it and make it look like new!
#1017
Start with http://www.trimlok.com/
Thanks for taking this on, Alex.
#1019
Archive Gatekeeper
Don't worry, William has a plan to address it.
![](https://webfiles.uci.edu/redwards/public/William%20solution%20for%20dirty%20rear%20lock%204-2-16.jpg)
