Help with caliper piston boots
Hi Guys and Gals,
Looking for some advice. Need to replace the rear brake caliper piston boots on the Cayman...starting to crack. I am assuming I do not have to change the inner piston seals....no leaks.
Can I just change the rubber boots without removing the pistons?
Any suggestions on where I can get replacement rubber boots or get the work done?
Merci
Merci
Will be sourcing them from Andrew @ WeTune, the task is an easy one as no need to remove the pistons. Will get to spend some quality time with the calipers this winter, gotta treat them nice or else bad things may happen
