Some jacking points are meant to change a spare tire in case of emegency, others are meant to lift the car. If you lift a car and leave it suspended from emergency jacking points, you will damage the floor and potentially the panels attached to your floor since these jacking points were not meant to bear the full weight of you vehicle. What model p-car do you have?
