944 / 924S pièces à donner - free parts
I couldn't sell these parts so it's time to give them away... please take it all
Home made trailer hitch
https://rennlist.com/forums/924-931-...ler-hitch.html
Used fuel rail with pressure regulators (untested) and one injector.
Arnnworx 9131-944 timing belt and balance belt gauge. This is no longer available and is not perfect, but helped me to learn how to tension the belts. Use with the 90 degree twist…
Power steering rack depowered. I preferred powered steering, but this has the advantage of no fluid leaks and save some pounds.
15 half-shaft bolts, new
Exhaust cat-back. The pipe is good but the muffler is rusting. I kept it to possibly weld in an after market muffler
2 new steering rack – tie rod boots, part no. 191419831
2 early tie rods with OK steering rack boots. Ball joints are not loose but the ball joint boots are torn.
Box of power steering parts including power steering pump, 2 used fluid reservoirs, fluid cooler coil and hoses, misc hoses
2 broken transmission mounts, if you want to rebuild them yourself
Clutch master cylinder and slave cylinder for rebuild
1 used engine mount, original Porsche part, looks OK
Box of used brake pads and shoes.
