928 brakes
I have a 1978 Porsche 928 and want to convert to S4 brakes. What is involved? I assume I need new discs and either an adapter for the calipers or S4 spindles for the front brakes. Not sure about the back brakes. Do I need a new master cylinder?
go to the "Water Cooled ...." major forum set and select the 928 forum.
Post this there, or do a search and you will get all the info you need.
Cheers, Ian
Cheers, Ian
Can't help you with your question... but I too have a '78 928. Are you in the Montreal area? It is always useful to specify your location in your member profile.
