where can i get silicon rocker gaskets for my 965 turbo 2
any idea where i can purchse the silicon gaskets for the 965 turbo 2 as i willbe adjusting the lifters in the next few weeks and need obviously new gaskets are the silicon ones anygood
gasket answer
these guys do silicon gaskets
the issue is to get the right gasket compression with the correct bolt torque which is extremely low so the bolts tend to vibrate loose.
The best approach is to use shouldered bolts so the gasket compression is correct and you can also get the bolt good and tight. But I think on your model it has studs and lock nuts?
Marton
Marton
