Picture upload broken
About 2 weeks ago, I noticed this function was broken:
http://forums.rennlist.com/upload/memberupload.php
Just came back from a trip and it's still down, so perhaps admin doesn't know about it yet.
Upload Pictures
I've always used this link to upload pictures to rennlist http://mall.rennlist.com/upload.asp which is in the top right. Now all I get is this. Can this be fixed?
max_filesize(30000); $my_uploader->max_image_size(800, 800); $my_uploader->upload('userfile', 'image/gif', '.gif'); $my_uploader->save_file('uploads/', 2); if ($my_uploader->error) { print($my_uploader->error . "
\n"); } else { print("Thanks for uploading " . $my_uploader->file['name'] . "
\n"); } */ // Create a new instance of the class $my_uploader = new uploader($_POST['language']); // for error messages in french, try: uploader('fr'); // OPTIONAL: set the max filesize of uploadable files in bytes $my_uploader->max_filesize(200000); // OPTIONAL: if you're uploading images, you can set the max pixel dimensions $my_uploader->max_image_size(2400, 2400); // max_image_size($width, $height) // UPLOAD the file if ($my_uploader->upload($upload_file_name, $acceptable_file_types, $default_extension)) { $my_uploader->save_file($path, $mode); } if ($my_uploader->error) { echo $my_uploader->error . "
\n"; } else { // Successful upload! print"
"; print($my_uploader->file['name'] . "
Congratulations! Your file was successfully uploaded!
To Upload another picture - click here
or use the form at the bottom of this page
"); // Print all the array details... //print_r($my_uploader->file); // ...or print the file if(stristr($my_uploader->file['type'], "image")) { echo "file['name'] . "\" border=\"0\" alt=\"\">"; print"
Please COPY THIS URL:
http://forums.rennlist.com/upload/"; print($my_uploader->file['name']); print"
"; } else { $fp = fopen($path . $my_uploader->file['name'], "r"); while(!feof($fp)) { $line = fgets($fp, 255); echo $line; } if ($fp) { fclose($fp); } } } } print"
"; #--------------------------------# # HTML FORM #--------------------------------# ?>
Hi everyone,
Could you please upload your photos here instead?
https://rennlist.com/forums/album.php?do=addalbum
We're working to address the issues with the old gallery, however it's rather a large problem, and operates on machines separate from the ones running the community today.
cheers,
robb
cheers,
robb
Hi Graham,
We were forced to disable the uploader after several different malicious packages were left on our servers as a result. We believe that we have solved this issue, and as of last night, the uploader should be functioning again. However, I would like to suggest that everyone get into the habit of uploading images into the new, albums product that is tied to the vBulletin.
We are focussing our future development efforts, and product additions around the albums, as it's integrated with the vB, whereas the older Galleries product is entirely separate, in fact, it runs on a 486!
cheers,
robb
cheers,
robb
