Animated GIFs are disabled?!!?
Sharkaholic
New computer at work and ever since all the animated GIFs are there but not animated? How do I adjust the settings to reactivate them?
PS: I'm running windows XP on a HP with a Pent 4 and 504mb of ram.
Check your firewall settings as this will stop the gifs from running.
Start - Settings - Control Panel - Windows Firewall.
This is assuming that you are running windows firewall and it is turned on. If you have any other firewall running, then you would need to check those settings. If you don't have windows firewall running and you are not the network administrator, then you would need to speak that individual about this.
Good luck!
Good luck!
Sharkaholic
Ok thanks, looks like that is exactly what happened. They put in a new computer here and changed the firewall settings effectively shutting them down.
Thanks for your help!!
