Can't upload photo-not listed as a member
I received this message after trying to sign in:
Sorry - but you are not listed as a current Rennlist Member. -
Can I be listed?
Can I be listed?
I was able to up load using John D. instructions from the Admin post, just concerned that the database thinks I'm not a member.
John D. post:
If your Member Number is delayed, so you are unable to get into the Member area - simply bookmark this URL:
http://forums.rennlist.com/upload/memberupload.php
It will allow you to upload pictures right from your computer and display them in your posts!
John D.
John D. post:
John D.
Hey John!!!
Let me ping Jenn to take a look at the Member database - it's usually a difference in the ZIP codes that causes the issue... In the meantime - in that Member help section, you should also see links for the Classifieds, upload - etc....
Thanks!!!!
John D.
Thanks!!!!
John D.
