Posting photos question
Every time I try and post a photo I get back that its too large and I have to reduce it to some smaller size.....less than 250x250 or something like that.....and when it shows up on a thread it is so small the details go missing.....take this one for example....but I notice many of you guys get almsot full width ...... how?.......When I put a photo on I use the mamage attachments in the post thread ..... is there another way???
David,
Click on the following icon:
Then simply drop in the URL of the image you are supplying (naturally the image needs to be hosted somewhere). I tend to reduce mine to somewhere around 700 x 600 K or so. If the image comes in too big, I go back to my image hosting site and simply reduce it by 75% or 50% (as needed).
I hope that did not add confusion
Mark: Good morning!
Andreas
Mark: Good morning!
Andreas
Click "File -> Save as"
Format "JPEG"
Click "Save"
Below the Cancel button, tick to select "Preview"
Under Image Options use the slider to reduce (right to left) from "large file" to "small file"
as you move the slider, at the bottom of the dialog box it shows the resultant file size in kb
Hope this helps.
Marc
Format "JPEG"
Click "Save"
Hope this helps.
Marc
