Access Issues : Internal Server 500 Error when accessing via VPN
Rennlist Lifetime Member
Has something changed in the server config?
I've been able to access via my corporate VPN service for months (actually years)...for some reason, something has changed where I can no longer access Rennlist when I have my VPN client running (actually, I also cannot access Ford-Trucks.com which is also an IB site).
If I disable the VPN, I can connect fine...if I re-enable the VPN session, I can't connect.
Thanks much,
Rick
Thanks much,
Rick
IB Staff
Hi Rick,
I am not aware of anything, however if you're experiencing the same issue on Ford-Trucks, something must have changed on our end. Do you know when this issue first began for you? Do you use Facebook, gmail, or yahoo to login, or do you use the traditional username/password method?
cheers,
robb
cheers,
robb
Robb,
I believe it started right around the first of the month. My sense is that it's MTU negotiation related...if I force my MTU to a lower number, it will work. If I reset it to auto-negotiation, it won't work. I'm still looking at things on my end as well.
Thanks,
Rick
Thanks,
Rick
IB Staff
Hey Rick,
I've checked with the tech guys on our end, and nobody is aware of any changes on our end, which would have caused this to happen. Are you able to find out if perhaps something changed on your end?
cheers,
robb
cheers,
robb
Our network guys keep telling me that nothing has changed on our VPN setup (Cisco router) - but it clearly appears to be MTU related.
If I do a ping test, I can increase packet size up to 995 bytes with success...as soon as I increase it to 996 bytes, I cannot get the ping test to complete.
C:\Users\rfairwea>ping forums.rennlist.com -l 995
Pinging forums.rennlist.com [98.158.194.188] with 995 bytes of data:
Reply from 98.158.194.188: bytes=995 time=125ms TTL=229
Reply from 98.158.194.188: bytes=995 time=123ms TTL=229
Reply from 98.158.194.188: bytes=995 time=128ms TTL=229
Reply from 98.158.194.188: bytes=995 time=124ms TTL=229
Ping statistics for 98.158.194.188:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 123ms, Maximum = 128ms, Average = 125ms
C:\Users\rfairwea>ping forums.rennlist.com -l 996
Pinging forums.rennlist.com [98.158.194.188] with 996 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
