Log in issues
Old Oct 19, 2007 | 09:56 PM
ErnestSw's Avatar
ErnestSw
Default Log in issues
Ustawuz I could log in and stay logged in. Last few days I have to log in almost every time I go to Rennlist. Anyone else having this problem?
Old Oct 19, 2007 | 10:42 PM
FlyingDog's Avatar
FlyingDog
A supercharger would solve your problem.
(That and checking the 'remember me' box.)
Old Oct 20, 2007 | 02:49 AM
Jim M.'s Avatar
Jim M.
I agree, but then he would have head gasket problems. And NO, no log in problems here.
Jim Mayzurk
93 GTS 5-spd
Old Oct 20, 2007 | 03:20 AM
John Struthers's Avatar
John Struthers
User
Wink
Ern,
What type of log are you using?
Actually, I've had the issue rear-up intermittently.
However, I also manually remove history, files, cookies intermittently via internet options
and clear accumulated trash (www whatever) as well via Computer>C drive>windows>Temp.
BUT! I don't keep track of the obvious clearings and the odd intermittent droppings of site log on's.
Then again, if you have an ancient Compaq Presario with less memory than the average resident
of the Alzheimer Wing of the Happy Hollow Home for the Indigent Elderly and a 333mhz clock/sundial speed using the infrequently used TeePee browser, associated smoke signal entry point (SSEI),
and the fabled Windows (Manhole Cover) conversion alogrithims ... you get my drift.
However, I have no doubt that your camera -let alone your computer- has more features, power, and better software than this indestructable lump of mine.
Do you stay logged on more than one site?
Some of the Poker sites will bump the Renn and even the browser off line.
OR....as mentioned above....
BTW
As a note of caution for one of TexMex upbringing, please be aware of the -Yankee- Moose, and Elk mating season and adjust your morning walks accordingly. While there is nothing quite like getting
ear-tongued by a bull moose ... it will only get worse!
Also the freeze line up there is a minimum of 3 1/2 feet so you'll have to dig a pretty big hole to keep the 928 from freezing.
Old Oct 20, 2007 | 02:41 PM
Garth S's Avatar
Garth S
A little Amsoil poured over the keyboard should solve this one ....
Old Oct 20, 2007 | 09:10 PM
Randy V's Avatar
Randy V
25 Year Member
Turn cookies on.
Moved to the Help forum.
