Forum Search
Rennlist Site Sponsor
Interesting - I repeated your wallyp search, worked fine. I then searched for "rear seat" remove and got a blank screen again...
I have reported this to John/Jen a couple of times, but no response yet. I don't know whether the glitch is on my end or their end.
I have had the same search problem, where the result is only a blank page. I've figured that I was using too many search terms, and had stumbled onto a glitch, but apparently that's not the case, or at least not exclusively.
Yup..i get the same thing as well. Has been like that for a few weeks i think.
Using the advance search for Supercharger...turbo et...
I get the blank screen with "done" in the lower left.
HOWEVER..if this helps. If i search a USER NAME under the advance search feature.. ie "find post started by user", it works fine. HTH
Hi All...
Sorry about that!!! I forgot to post back after fixing that Search BUG.. Can you tell me if it's working for you now?? I kept using Wally's search "rear seat delete" across all the forums as a "search" - until it worked.. I hope I fixed it for all the searches...
Also - Mike....
The "Classifieds" is a different issue altogether (and is also a different problem?) Usually they won't open due to an issue/setting in your browser. Try these fixes:
https://rennlist.com/forums/rennlist-forum-glitches-post-them-here-test-posts-are-permitted/90935-question-the-classified-ads-or-link-does-not-appear.html
Best to you!
John D.
Also - Mike....
Best to you!
John D.
