Cold start 997tt
any suggestions for cold -20c and below starts. Avoid it when. Possible but kinda cringed when my 997 turbo barely started today. Good thing for the agm battery. Asked dealer and he didn't have any suggestions.
anyone every put heat pad on oil tank? Fresh oil change back in november.
Captain Obvious
Super User
Super User
I had an oil pan heater pad on my old TDI and it worked really well. I also used to use an electric battery blanket on another TDI that worked well too. The problem with the oil pan warmer is that if not installed properly and the pad comes off the pan while you have a plastic cover under the engine. This can easily casue a fire. . Therefore, I would recomend a battery blanket instead, CT sells them.
+1, I'd check the battery and alternator
Oil heaters on tank and possibly crankcase, and battery blanket/heater would be beneficial as well but not required IMO.
Also IMO, this would be the one time(freezing cold temps.) that I recommend 0w40 oil.
Would love to see some 997tt winter pics as well
Cheers,
Rob
Cheers,
Rob
0w40 mobil, battery is new and strong, but a battery blanket would be something simple to try.
Spark plugs are original but car only has 30k on it. test drove one with 13k and it was same thing in summer. need to turn over more than any gas vehicle ive driven. Is this normal for non direct injection p-cars
Ok, I was thinking you were having issue with it cranking over, it taking time to 'catch' is different altogether.
New plugs + coils, fuel filter, and make sure MAFs and O2's are within range.
How long does it crank before firing?
was going to wait til 40k to do plugs/coils if it wasn't necessary. my guess would be 5-6 ish second to start at -24
Before cranking the key always put it in the on position for 5 seconds before turning the car on. helps when its real cold.
try go-ran's idea, it primes the fuel system/pump runs.
if driven fairly hard, 40k is a fairly long time to run plugs in a TT...
5-6seconds of cranking does seem long, but not horrible...
Captain Obvious
Super User
Super User
If only takes 5-6 sec at -24C, I would consider normal. It take a lot of energy to start any engine in a cold like that. The engine needs twice the energy it going ajd the battery only produces half as much as it can so, it's normal for any engine to be a little slow cranking in a cold like that. I don't think there is anything wrong with your plugs or coils.
