Tread pattern and rim cleaning
I posted over in the Wheel and tire forum but thought I'd probably get a quicker response here. I've got two questions for you rim and tire guru's.
1) I have a set of Michelin pilot alpin snow tires that I'm looking to sell for a friend. Two of the tires have a different tread pattern. I'm assuming these two are just a newer model as they are both Michelin pilot alpin tires. My question is will this difference in tread pattern affect performance in the snow?
2) I have one rim that has a hard black film on them that I cannot get off. I have no idea what it is. Almost looks like the tire slime that is used for temp repairs. Any suggestions on what I could do to get it off?
Thanks for your input as always. Pics below
1) both will be good, people get wayyyy too paranoid about mixing tires...IIRC left side is the newer Michelin model, PA3 vs PA2...tread depth beats all for winter tires IMHO
2) I'd bet any good wheel cleaner should get that off, spray on, scrub gently with a paint brush,,,clean.
Sonax and a wheel brush should get that stuff off. Sonax or not so brand named Metal-X is like cheating when it comes to wheel cleaning (still pH neutral so its paint/bodywork safe).
Be carefull Mike .. the more harsh chemical you go and out of PH balance the more damage you can do to the finish on the rim. can you go mechanical with a plastic spatula or seomething hard enough for the contaminant but softer than the finish ?
i would reach out to a detailer .. may be worh it . there used to be one that hung out here and gave advice time to time
Wes R or something i think .
i think after all of this I think Imre and I are going to wake up to one of two things soon ..
A Massive explosion that can be heard clear across Cambrige,
Or some bald dude with Arms like popeye wandering around Cambridge like hes on some serious chemicals
