Borrow a DME relay for a 993?
Old May 24, 2014 | 09:03 AM
vern1's Avatar
vern1
Default Borrow a DME relay for a 993?
I haven't started my 993 since last fall and when I tried the other day it won't start. It cranks like crazy so I think it might be the dme relay and of course I don't have a spare.
Anyone have a spare that I could borrow just to see if that's the problem? I am in the Beaches and would be happy to pick it up this morning and return same day
Just want to find out the problem before I drop +$100 for a new one
Old May 24, 2014 | 09:23 AM
DJF1's Avatar
DJF1
you are welcome to borrow mine. pls let me know
Old May 24, 2014 | 09:26 AM
vern1's Avatar
vern1
Awesome Danny, where are you located? Can PM me if you like. I could come by any time
Rick
Old May 24, 2014 | 10:51 AM
vern1's Avatar
vern1
I think Danny is in Burlington. Anyone in the Beaches or east end? Otherwise Danny I can make a run out there this aft or tomorrow. Many thanks
Old May 24, 2014 | 06:38 PM
mr944's Avatar
mr944
if you didn't drive out yet let me know. i'm in your area.
Old May 24, 2014 | 06:59 PM
vern1's Avatar
vern1
I haven't yet. Would be happy to come by tomorrow if your local?
Rick
Old May 24, 2014 | 08:02 PM
Paul902's Avatar
Paul902
Vern,
do you have the original 944 p/n relay? There is a thread on the 993 board that shows the solder joints failing is the usual culprit on these. If you have access to a soldering iron you can repair it very inexpensively. If you don't, I'd be happy to try to fix it, or sell you a spare. When mine busted I bought a second spare, then found out about the solder joints and the first one was repaired, so now I have three.
Old May 24, 2014 | 08:46 PM
IXLR8's Avatar
IXLR8
Just want to find out the problem before I drop +$100 for a new one.
You can do a quick test. Bypass the relay (remove it) by using some wire and crimp-on male connectors. Less than a buck in materials.
I think 30 (power), 87 and 87b.
Old May 24, 2014 | 08:57 PM
vern1's Avatar
vern1
Thanks Paul and IXLR8
Mr944 is going to lend me his tomorrow so I can see if that's the problem
Much appreciated all around
Old May 24, 2014 | 11:40 PM
Turbodan's Avatar
Turbodan
with the key on you should be able to hear the fuel pump if the relay is working, it is near the right rear tire.
I also have one but it sounds like you are taken care of.
Old May 24, 2014 | 11:42 PM
IXLR8's Avatar
IXLR8
Right front tire maybe.
Old May 25, 2014 | 08:40 AM
Rally Guy's Avatar
Rally Guy
You guys get this sorted? I'm just north of you (5 min) and am happy to lend you my DME relay and or open up yours and fix it. I'll ba back from early hockey about 10am.
Rk
Old May 25, 2014 | 03:11 PM
vern1's Avatar
vern1
Borrowed Mr944's DME and it fired right up!! Problem identified! Thanks again mr944!!
And also thanks to all that offered to help. It was an old 944 part number. Will have a DME from the US in a couple of weeks and a spare as well for $50 so less than 25% of the cost of 1 at the dealer here.....
