Help with Oil change
Old 08-01-2013 | 02:30 AM
Turbodan's Avatar
Turbodan
I use metal snips to cut open the oil filters, and return the oil to Canadian Tire also for free.
Old 08-01-2013 | 02:33 AM
porsche0nut's Avatar
porsche0nut
Friday at noon... I'll try to escape the office
Old 08-01-2013 | 08:59 AM
Chimcu's Avatar
Chimcu
Originally Posted by Torontoworker
I did an oil change today on my 996. Is the filter housing on the 997 the same as the 996? If so I have the metal filter wrench you can use. The oil drain plug is an 8mm hex that is real easy to screw up as it's quite the soft type of aluminum and mine was a little iffy so I ran out to Palff today and got another one for $15 and a new crush washer. You don't really need a torque wrench for this - it really is just a feel thing when you tighten it. If you want to use the torque wrench cause it's sitting in your tool box like mine unused - go ahead but don't run out and buy one just for that purpose. Same for the filter housing - something like 13lbs or 17lbs torque - that's not even a 1/4 turn after hand tight. It's more important that you get the O ring on the right groove! Get it wrong and you'll be leaking oil all over - ask me how I know? Porsche in it's weird wisdom actually have two groves that the O ring can be fit upon and the one closest to the lip isn't it! Remember to fill up the housing with oil - place the filter on the oil return boss and then slowly push the housing up and then start threading it in. Too much oil and it spills out over the housing. I fill it about half filled and the filter volume usually takes up the rest. You do this so you don't get a dry start and the pump sucks air instead of oil. Jacks are fine but I back the car up onto patio stones as you only require an extra three inches of clearance to slide an oil tray under the car and my car is lower then M030 height and the Canadian Tire tray get's under there with room to spare. It's also helpful that my driveway slopes away from the garage floor. The biggest headache is transferring the used oil out of the tray and not spilling it! I put the 5 liter bottles in a second tray and using a funnel slowly pour the used oil back into the bottles and then bring them into Mississauga's recycling center where they take the oil for free off my hands. It's also a good time to check your air filter while the oil is draining. I usually cut open the oil filter for a look see on the inside of it - it's messy but you'll either scare yourself by finding 'things' or feel good about your engine if it's nice and clean! Dice roll...
Jeezz.. I got A.D.D here .. try to put instructions in point form pls .. Derek, did you get all that, make sure you do it right or the car will fall on you .. I'll print it out and put it in "coles" notes.. Greg.. you're more than welcome to come.. just let me know ahead of time.. I think it's going to be a nice day so I'll get us some food that we can actually stand and watch Derek *** up
Old 08-01-2013 | 09:25 AM
zer026T's Avatar
zer026T
Like Torontoworker, I also don't bother with the jack.. I just back my car onto a couple of small wooden planks (2"x6") at the edge of the cement pad in my garage (I have a 1-2" drop-off to the driveway). The extra clearance from the planks gives me enough room to perform the oil change with ease. It's a little tight but saves me from digging out the jacks/stand.
Old 08-01-2013 | 09:55 AM
theiceman's Avatar
theiceman
Team Owner
Darn i have plans for Friday guys as that is my busiest day at work
have fun guys ..
Old 08-01-2013 | 10:21 AM
Torontoworker's Avatar
Torontoworker
And this is where I also say: 'There is no expressed or implied warranty in the service advice given...'
PM me your address and what time your going to do this and I'll see if I can make it.
Old 08-01-2013 | 10:28 AM
cash-man's Avatar
cash-man
Yeah. I got all of that. Thanks Kevin. I'll jot down some notes so I can bark orders at you through my bullhorn
You're doin all the dirty work. Come to think of it, you the perfect size for this job. No jacks required!
Old 08-01-2013 | 03:32 PM
Zookie's Avatar
Zookie
Kevin, I can help ya, I do mine all the time. Call me and let me know if you got all the tools
Old 08-01-2013 | 05:29 PM
Jonathon Rolstin's Avatar
Jonathon Rolstin
997 is one of the easiest cars to change oil on. You should not have a problem Kev. If you have any questions you can call me.
I would come by to show you but I have a real job now and can't take time off because I'm too important! hahahahaha
Old 08-01-2013 | 08:18 PM
Chimcu's Avatar
Chimcu
Real job eh... more like a real gf and not 'lefty and righty'... if mine was the 3.8 at least the filter is in the engine bay...
Anyhow tomorrow is going to be nice so well stand and do some keg burgers...or something...not sure yet...
Old 08-01-2013 | 11:53 PM
Chimcu's Avatar
Chimcu
may be missing an oil filter wrench.. the guy I am buying from is very slow in responding between text messages..sheesh...
Old 08-02-2013 | 08:27 AM
BioBanker's Avatar
BioBanker
Im in the Beach and have a filter wrench.
If you need one and someone can swing by my place to pick it up, its yours to borrow.
Old 08-02-2013 | 10:46 AM
Torontoworker
Sorry, hung up at home on a household issue. Tip for today: Oil drain bolt and filter housing removal is clockwise to remove.
Old 08-02-2013 | 11:37 AM
Chimcu's Avatar
Chimcu
deal went through and i got myself a oil wrench filter..thx though
Old 08-02-2013 | 08:34 PM
Chimcu's Avatar
Chimcu
so it was a great success .. (the car hasn't blown up just yet) ... I have to say that changing oil on these 997.1 is the pimpliest thing I've ever done. My gloves didn't' even dirty.... Dealership.. you can kiss my as**
