Canucks running M tunes?
Was looking into it but never went for it, still A-Tune, works great
Was quick to install, you can easily do it in an afternoon. I was running an Autothority MAF prior to the m-tune. The M-tune is light years ahead of the Autothority MAF setup. The throttle response is much quicker, the power is much smoother and more immediate.
I have nothing bad to say about the setup.
Dal.
Dal.
Man im soooo pumped to get this thing. Im also throwing on an msd 6a/tach adapter/blaster 2 coil, 2.25" hardpipes, moroso air oil separator, and a couple other non performance items. was running a huntley maf, 55lb injectors, and split second fuel controlller, just excited to get 3d mapping
Oh yea, I also got the 80lb fuel injectors with the m-tune. Don't want to ever have to worry about maxing out the old injectors. I'm also running a 2.8l stroker motor with a k27/6 and full 3" turbo back exhaust. . . Even with the huge injectors the car runs and idles perfectly! I'm very impressed with the m-tune. I might upgrade to the msd blaster hvc2 coil and get the chip updated to support it later.
Bumper, where are you located?
